How To Widen 22-5/8" Window Frame To 23" - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-16-2008, 11:57 PM   #1
sestivers's Avatar
Rewards Points: 103
How to widen 22-5/8" window frame to 23"
I want to hang new mini blinds inside one window frame. It's supposed to be a 23" wide window frame but the trim inside the window frame makes the width more like 22-5/8". The "standard" 23" mini blinds are 22-1/2" wide and don't fit... I need my window frame to be about 1/4" wider (or the blinds 1/4" narrower).
I could get custom blinds made (but don't want to) or supposedly could cut the blinds to be narrower (but don't think I would get quality results, I don't even know what kind of tools you're supposed to use to do that). What I assume is the best solution is to take down the side trim and plane each piece to be thinner by about 1/8" or 3/16". The trim is basically 5/8 x 4" stained pine boards.
But, how do I do this? I don't have appropriate tools to do it myself, but if I can find a friend with a table saw would that work? I'm also open to other solutions.
Steve
Last edited by AtlanticWBConst.; 03-17-2008 at 04:32 AM. Reason: Clarified Question in Title
sestivers is online now   Reply With Quote
Old 03-17-2008, 10:34 AM   #2
Home Remodeler
Rewards Points: 164
Most big box stores will cut your blinds to fit for free.
mikey48 is offline   Reply With Quote
Old 03-17-2008, 09:28 PM   #3
www.handyguyspodcast.com
Have a big box store cut them to size. Not a big deal. They will look fine.
borninpa is offline   Reply With Quote
Old 03-18-2008, 07:20 AM   #4
General Contractor
joasis's Avatar
Trust us, trimming the blinds is a much better alternative then shaving parts of the window frame. I will say, this is the first time I have run across this kind of question.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
joasis is offline   Reply With Quote
Old 03-18-2008, 06:10 PM   #5
Rewards Points: 5,336
Steve, have you bought the blinds?
Ron
Old 03-19-2008, 12:09 AM   #6
+1 Don't even think about trimming down the window frame vs blinds, you are just opening a huge can of worms if you do.
sparky120/240 is offline   Reply With Quote
Vinyl window stuck in wood frame rlcarter Remodeling 7 09-26-2007 06:29 PM
Replacing Window Frame SebasC Remodeling 6 09-13-2007 02:09 PM
How to repair deterioration on inside of window frame? darsunt Carpentry 2 08-13-2007 04:40 PM
How do I repair my window frame sherlock Carpentry 18 12-20-2006 09:54 AM
Window Frame Materials - Vinyl vs Aluminum vs Fiberglass chrison600 Building & Construction 2 10-09-2005 12:13 PM
