-   -   How to widen 22-5/8" window frame to 23" (http://www.diychatroom.com/f2/how-widen-22-5-8-window-frame-23-a-18604/)
sestivers 03-16-2008 10:57 PM
I want to hang new mini blinds inside one window frame. It's supposed to be a 23" wide window frame but the trim inside the window frame makes the width more like 22-5/8". The "standard" 23" mini blinds are 22-1/2" wide and don't fit... I need my window frame to be about 1/4" wider (or the blinds 1/4" narrower).
I could get custom blinds made (but don't want to) or supposedly could cut the blinds to be narrower (but don't think I would get quality results, I don't even know what kind of tools you're supposed to use to do that). What I assume is the best solution is to take down the side trim and plane each piece to be thinner by about 1/8" or 3/16". The trim is basically 5/8 x 4" stained pine boards.
But, how do I do this? I don't have appropriate tools to do it myself, but if I can find a friend with a table saw would that work? I'm also open to other solutions.
mikey48 03-17-2008 09:34 AM
Most big box stores will cut your blinds to fit for free.
borninpa 03-17-2008 08:28 PM
Have a big box store cut them to size. Not a big deal. They will look fine.
joasis 03-18-2008 06:20 AM
Trust us, trimming the blinds is a much better alternative then shaving parts of the window frame. I will say, this is the first time I have run across this kind of question.
Ron6519 03-18-2008 05:10 PM
Steve, have you bought the blinds?
Ron
sparky120/240 03-18-2008 11:09 PM
+1 Don't even think about trimming down the window frame vs blinds, you are just opening a huge can of worms if you do.
