How/where Do I Buy A SMALL Amount Of Vapour Barrier? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-05-2010, 11:29 PM   #1
How/where do I buy a SMALL amount of vapour barrier?
I have just replaced a short section of wall studs in my basement, and to finish the job I need a piece of vapour barrier (6 mil plastic) about 6 ft x 6 ft.
Home Depot and Lowes will be glad to sell me a minimum quantity of 100 ft ...
Does anyone know where to buy small quantities?
Is there something else that is effective that I can buy instead? Maybe plastic used in double glazing kits (don't know how thick that is)?
Any help appreciated...
GuyBooth is offline   Reply With Quote
Old 07-06-2010, 07:15 AM   #2
That 100 ft roll is probably only a few dollars, so you have extra for the next time it is needed.
The Following User Says Thank You to Just Bill For This Useful Post:
gregzoll (04-26-2012)
Old 07-06-2010, 05:29 PM   #3
$67 - unless I want to also buy a ton of tape, at which point I get it in 12" strips for less money.
Not a satisfactory solution for me - and I really don't want to be storing 90' of plastic in my basement. This is the first time I have needed any vapour barrier in over 25 years owning a home - I don't expect to need any more for another 25 years, if ever....
Old 07-06-2010, 05:33 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Go to the paint department and get a plastic drop cloth, they come in various sizes and thickness.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 07-06-2010, 06:13 PM   #5
well
Try some 6 mil contractor garbage bags and duct tape.
big roll of plastic is nice to have for storms...tree on the house etc. you or the neighbors.
Big Bob is offline   Reply With Quote
Old 07-06-2010, 07:19 PM   #6
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 70
I'd buy the VP roll and call it a day, that stuff can come in handy for other situations too. I had a similar situation and now I have a full roll. Ended up using some to put my server equipment on top so it's not directly on the concrete floor. I've actually thought of covering my entire basement as a temp flooring solution so I can walk without footwear. (floor is very rough and full of drywall dust that will never fully come out) When I finish the basement I could probably pull it off and reuse for walls or even leave it if I decide to put floating floor.
Old 07-07-2010, 10:47 AM   #7
Rewards Points: 256
Tried craigslist?
moneymgmt is offline   Reply With Quote
Old 07-07-2010, 11:30 PM   #8
Finally found some in the paint department at HD - is only 3.5 mil but is labelled as Vapour Barrier (as opposed to just General Purpose), and will do the job I'm looking for.
Old 07-08-2010, 06:12 AM   #9
Rewards Points: 4,534
ohfergawdsake VAPOR BARRIER IS ANY NON-VAPOR PERMEABLE COATINGt,,, i don't think anyone expected you were THAT much of a newbie next time, just forget what it sez on the box sometimes you gotta get past google or the end of your nose
but tnx for the joke, too,,, nice way to start the day ! ! ! !
Old 07-09-2010, 12:34 AM   #10
Always learning...
fetzer85's Avatar
Rewards Points: 262
I see you already got what you needed, but for reference to anyone who reads this thread in the future in search of an answer, I bought a roll of 10' x 25' 6mil plastic at Walmart. It was awhile ago so I don't recall the exact price, but it was much less than $67...probably more like $15-$20.
The garbage bag idea is good but I've never seen a bag much thicker than 2mils.
fetzer85 is offline   Reply With Quote
Old 02-16-2012, 10:01 PM   #11
Buy a cheap clear vinyl shower curtain. Dollar store, Kmart etc. Another possibility is mattress wrap.
fix it guy is offline   Reply With Quote
Old 04-26-2012, 01:25 PM   #12
Ace Hardware
You can find small quantities of 6 mil vapor barrier at Ace Hardware.
btiller1866 is offline   Reply With Quote
Old 04-26-2012, 02:59 PM   #13
Are there any homes being built near you? If so, ask the site foreman if you can dumpster dive. I work in construction. You'd be amazed at the extra stuff they throw away.
Sent from my iPhone using DIY Forum
RonS1985 is offline   Reply With Quote
The Following User Says Thank You to RonS1985 For This Useful Post:
woodworkbykirk (04-26-2012)
Old 04-26-2012, 03:25 PM   #14
In a little over my head
Rewards Points: 706
Shower curtain
ratherbefishing is offline   Reply With Quote
Old 04-26-2012, 07:54 PM   #15
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
the dumbster diving option is actually teh smartest.. or go to a true lumberyard as they sometimes sell it by the foot.
3.5 mil poly does not classify as vapor barrier its just masking plastic for paint, you need 6 mil for it to be a proper vapor barrier... the garbage bag idea is just plain stupid.. ive seen it done looks extremely amatuer if someone ever opens up that wall after the fact and sees it the first thing that they will wonder is homw much else was done this poorly
woodworkbykirk is offline   Reply With Quote
Tags
insulation , vapor barrier
Basement insulation / vapor barrier questions deepstuff Building & Construction 16 02-09-2012 10:11 AM
basement insulation and vapour barrier coolnes Remodeling 11 02-01-2009 09:56 AM
vapour barrier in part of room? bluejay Building & Construction 1 05-07-2008 07:31 AM
Installing insulation and vapor barrier to exterior basement walls Fernando Sinn Building & Construction 11 04-11-2008 12:11 PM
moisture barrier - help! jediracer Carpentry 12 10-03-2006 07:32 PM
