How To Tighten Slack In A Dog Trolley - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-17-2009, 04:44 PM   #1
How to tighten slack in a dog trolley
Hey guys i have a dog trolley for my dog and there is a great deal in the slack now. it uses rope clams and when i get it tight and go to tighten the clamps it loosens up.
mine runs from my house to my back shed
B_wit_92 is offline   Reply With Quote
Old 08-17-2009, 06:36 PM   #2
Instead of using rope, you might want to go with a braided cable then turnbuckle the ends. That way you can just tighten up the turnbuckle to tighten. My .02 cents
These listed here are not the chepest but will give you an idea of what I talking about.
http://store.wastewatersupplies.com/...ess-steel.html
mark942 is offline   Reply With Quote
Old 08-17-2009, 11:04 PM   #3
What's the point of the turn buckle though?
Old 08-18-2009, 07:06 AM   #4
RippySkippy's Avatar
If/when the wire rope develops slack...by turning the turn buckle, with out much effort you can tighten it up. Depending on the size of shed, if it continually develops slack, you may be pulling the shed over gradually.
You could always run the cable from your house to the shed through a pulley mounted to the exterior wall. Attach a counter weight to the cable, that would keep the cable tight all the time. The benefit would be that it would also allow Fido to pull against the cable and it will give, then retract when he calms down. Let me know if you need a sketch...
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 08-18-2009, 08:15 AM   #5
Registered User
Termite's Avatar
I moved this thread from the How-To Guides section.
Agreed, rope isn't going to stay tight for you. Cable is much more appropriate for this application, and the addition of a turnbuckle is the solution!
Old 08-18-2009, 02:29 PM   #6
its not a rope but rather a cable like this
Old 08-18-2009, 02:38 PM   #7
Old School
Willie T's Avatar
This is a great (and humane) idea. It eliminates the jerk to the dog's neck.
Willie T
Old 08-18-2009, 03:06 PM   #8
Newbie Bill
Rewards Points: 522
So it sounds like the problems are from these "rope clamps". I'm not exactly sure what those are. Someone else may know and can chime in. In the meantime, can you attach a photo of your setup?
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 08-18-2009, 03:08 PM   #9
Newbie Bill
Rewards Points: 522
It appears from the photo of the sky trolley package, it already has a turn buckle. It is the silver thing on the left side of the package.
Bill
Old 08-18-2009, 11:27 PM   #10
well that isnt the same kit i have. mine has hooks that you screw into the wall and then this is what i have holding the slack in the line
mine is the silver one in the bottom right of the image
Old 08-18-2009, 11:51 PM   #11
Rewards Points: 150
wow what kinda dog do you got?!
johnnyboy is offline   Reply With Quote
Old 08-19-2009, 07:36 AM   #12
Newbie Bill
Rewards Points: 522
OK, that will work. What you need from the hardware store is a Turn buckle (I think that is what it is called). It is like the one on the bottom left. You hook one end to the cable, the other to the U bolt you have and you twist it with a wrench and it tightens up.
Let us know how that goes.
Bill
Old 08-19-2009, 09:46 AM   #13
if you could send me a sketch of that?
Old 08-19-2009, 10:09 AM   #14
If the silver connection is not tightened down enough, or the wrong size for the wire it will slip
Old 08-20-2009, 08:02 AM   #15
Let me see what I can come up with...I'll try to get you something later in the day...
LMASD
Abloy Front Door Lock is loose - how to open to tighten Wayne_in_Canada Windows and Doors 4 09-23-2012 07:48 PM
how to unscrew or tighten old screws in the deck? renoet Carpentry 10 03-04-2009 02:42 PM
What tool to use to tighten this nut???? Monika2024 Plumbing 9 12-02-2008 07:05 AM
Very Small leak at Shower Valve on Cold Water Side, Threaded. Tighten it more or ? twilightcall Plumbing 3 08-25-2008 08:19 AM
Dog trolley mommaroot2004 Landscaping & Lawn Care 21 02-03-2008 07:24 PM
