How To Tell If Bathtub Is Acrylic Or Fiberglass? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-21-2013, 10:39 AM   #1
Rewards Points: 160
How to tell if bathtub is acrylic or fiberglass?
Hello. I'm not sure where I was suppose to post this in the forums so my best guess was here. I have a tub/shower combo with some hairline cracks in it that I need to repair. I was wondering if there is a way to tell if the material is acrylic or fiberglass so I can determine the correct repair procedure. Thanks
word2yamutha is offline   Reply With Quote
Old 06-21-2013, 05:10 PM   #2
PoleCat's Avatar
Rewards Points: 1,646
Fiberglass has a reek to it. If you are familiar with that particular bouquet then a close olfactory examination will tell you.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 06-22-2013, 11:08 AM   #3
Rewards Points: 160
I never know fiberglass had a bad smell to it. I honestly don't smell anything because I just cleaned it. Is there any other way to tell?
Old 06-22-2013, 11:36 AM   #4
Too Short? Cut it Again!
Fiberglass would display what the name suggests if you were to look at in on edge. Either resin and fiberglass cloth or matting is laid up in a mold or more likely for a tub surround, a slurry is sprayed into one over a gel coat layer.
An acrylic tub and surround would be vacuumed formed over a mold and would be formed out of a sheet of plastic.
Old 06-22-2013, 11:39 AM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 1,826
You need to find a cut opening.....fiberglass will have a few fibers....acrylic will be smoother.
If you can see under it....it's real obvious.....the underside will look like a bunch of straw compacted if it's FG
Old 06-22-2013, 12:22 PM   #6
Rewards Points: 160
Well there is no way to get behind it. So Im clueless on what to do
Old 06-22-2013, 01:16 PM   #7
PoleCat's Avatar
You can take off a knob and the escutcheon plate behind it then you will be able to examine the edge of the cut hole.
The Following User Says Thank You to PoleCat For This Useful Post:
user1007 (06-22-2013)
Old 06-22-2013, 02:48 PM   #8
Rewards Points: 13,740
If it's cracking it's from the tub not being supported properly.
Applying some form of coating is not going to do anything.
Old 06-22-2013, 06:37 PM   #9
Rewards Points: 160
Lol not sure why I didn't think of that Thanks
Old 06-23-2013, 10:15 AM   #10
Rewards Points: 160
Turn out to be fiberglass. Any products you guys recommend to fix it?
Old 06-23-2013, 11:56 PM   #11
Rewards Points: 274
Yeah definitely you can...
alexjoe is offline   Reply With Quote
fiberglass bathtub - remove integral foam leveling feet worthspending Plumbing 3 06-12-2013 10:02 AM
acrylic bathtub not level from front to back dave keene Kitchen & Bath Remodeling 4 03-09-2013 03:51 PM
Bathtub fiberglass surround schraggyj Tiling, ceramics, marble 2 08-21-2011 07:15 PM
Scratch in Acrylic Bathtub shadfly Kitchen & Bath Remodeling 5 07-24-2009 04:08 PM
