-   -   How to tell if bathtub is acrylic or fiberglass? (http://www.diychatroom.com/f2/how-tell-if-bathtub-acrylic-fiberglass-182245/)
word2yamutha 06-21-2013 10:39 AM
Hello. I'm not sure where I was suppose to post this in the forums so my best guess was here. I have a tub/shower combo with some hairline cracks in it that I need to repair. I was wondering if there is a way to tell if the material is acrylic or fiberglass so I can determine the correct repair procedure. Thanks
PoleCat 06-21-2013 05:10 PM
Fiberglass has a reek to it. If you are familiar with that particular bouquet then a close olfactory examination will tell you.
word2yamutha 06-22-2013 11:08 AM
I never know fiberglass had a bad smell to it. I honestly don't smell anything because I just cleaned it. Is there any other way to tell?
user1007 06-22-2013 11:36 AM
Fiberglass would display what the name suggests if you were to look at in on edge. Either resin and fiberglass cloth or matting is laid up in a mold or more likely for a tub surround, a slurry is sprayed into one over a gel coat layer.
An acrylic tub and surround would be vacuumed formed over a mold and would be formed out of a sheet of plastic.
ddawg16 06-22-2013 11:39 AM
You need to find a cut opening.....fiberglass will have a few fibers....acrylic will be smoother.
If you can see under it....it's real obvious.....the underside will look like a bunch of straw compacted if it's FG
word2yamutha 06-22-2013 12:22 PM
Well there is no way to get behind it. So Im clueless on what to do
PoleCat 06-22-2013 01:16 PM
You can take off a knob and the escutcheon plate behind it then you will be able to examine the edge of the cut hole.
joecaption 06-22-2013 02:48 PM
If it's cracking it's from the tub not being supported properly.
Applying some form of coating is not going to do anything.
word2yamutha 06-22-2013 06:37 PM
Lol not sure why I didn't think of that:laughing: Thanks
word2yamutha 06-23-2013 10:15 AM
Turn out to be fiberglass. Any products you guys recommend to fix it?
alexjoe 06-23-2013 11:56 PM
Yeah definitely you can...
