How To Support Patio Cover Posts - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-07-2010, 11:17 PM   #1
How to support patio cover posts
I recently purchased a home with a freestanding fiberglass patio cover. It appears the 4x4 posts were anchored to the concrete slab patio, using simpson brackets and condrete anchors. It seems fairly stable, however there is a slight sway to the entire structure when you lean on it. Is there a way to support the posts to add more stability? Thanks for any advice.
tver is offline   Reply With Quote
Old 10-07-2010, 11:25 PM   #2
jlhaslip's Avatar
Rewards Points: 2,206
Got a picture of the cover and another one of the post connection?
Are there any knee braces on the cover?
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 10-08-2010, 10:15 AM   #3
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
Location might help...... a solution in Hawaii might not be the same solution as one in Alaska.
CoconutPete is offline   Reply With Quote
Wood Patio Cover Post Grounding Madracki Electrical 10 07-04-2009 02:49 PM
Footer size for a monolithic patio that can support simple roof seth Building & Construction 2 05-19-2009 09:19 PM
Built a covered patio, now I'd like to cover over the stucco. Ideas? perpetualjon Building & Construction 7 03-23-2009 10:31 PM
Patio cover construction Scott44 Building & Construction 2 03-14-2009 10:10 AM
Patio Cover - Need help/suggestions DIYer Building & Construction 7 02-19-2006 09:00 PM
