How Strong Is Plaster & Lathe - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-23-2007, 10:00 AM   #1
Question
How strong is plaster & lathe
Hi,
I'm hanging a small cabinet on the bathroom wall. The house was built in 1952 and has plaster walls. Do I have to find the studs, or is the lathe strong enough to support a small cabinet?
Keith in Connecticut is offline   Reply With Quote
Old 08-23-2007, 12:56 PM   #2
Hi there,
It depends on the cabinet. Weight, size etc. I normally try and find studs for at least one of the screws. The other one I use toggle bolts. So far it all still hangs on the wall.
Don't bother using a studfinder as they don't work for lath and plaster. I use the high tech solution - measuring and tapping on the wall in different spots and listening for differences in sound.
Good luck.
Oldhouseowner is offline   Reply With Quote
Old 08-23-2007, 01:06 PM   #3
Tired, Cold, and Damp
slickshift's Avatar
Don't trust the lathe
It might hold, it might not
Find a stud...use the tap method
slickshift is offline   Reply With Quote
Old 08-23-2007, 04:01 PM   #4
Talking
Thanks for the tips. I really appreciate it.
Old 08-23-2007, 04:26 PM   #5
Custom Cabinet Maker
Keith, Oldhouse: check the baseboard, no I am not that crazy weeeeeeellll maybe Seriously folks, ur baseboard will be nailed into the studs.
JackM
skymaster is offline   Reply With Quote
Old 08-23-2007, 11:31 PM   #6
I actuallt found the baseboard thing out the hard way. Layed Parquet flooring 2 days after we moved in, put the baseboards back afterwards and tried to hit a nail in between studs - bouncy bouncy. A 2 x 2 feet area of plaster rumbled down. Bummer!
I appreciate what you guys are saying and again i would go into studs whenever possible. But sometimes there is just that one cabinet the wife wants somewhere and no second stud anywhere near there (Apart from me of course).
Old 08-24-2007, 10:46 AM   #7
Mod / ArchiBuilder
Cole's Avatar
I agree, do not trust the lathe.
Find the studs and attach the cabinet to them.
Cole is offline   Reply With Quote
Plaster to drywall joint question. ERIK2173 Remodeling 7 05-16-2009 04:58 PM
Plaster walls and Lathe Keith in Connecticut Remodeling 5 01-03-2008 07:36 PM
replacing lathe and plaster eager2lern Building & Construction 2 12-04-2006 12:52 PM
Plaster removal decision Sarai Remodeling 2 09-08-2006 03:15 PM
bathroom wall advice bigbrad123 General DIY Discussions 9 06-07-2006 07:26 AM
