-   -   How should I hang this cabinet?? (http://www.diychatroom.com/f2/how-should-i-hang-cabinet-128652/)
ranger12 01-03-2012 01:54 PM
OK, got a 12" wall cabinet, and an end shelf for either side.
This is not what we bought, but it looks just the same to give you an idea of what the end shelves are like: http://www.kitchenresourcedirect.com...white-857.html
Face frame of the main wall cabinet sticks out about 1/4" past the cabinet side. Sides of that cabinet are 1/2" thick, as are the mating panels of the side shelf units.
So...how would you hang?? I'm figuring to hang the 24" main cabinet, then add the 2 side shelves...pull the face frame tight, and shim 1/4" in back... What is the best way to attach them together? Screws, barrel bolts, etc???
Tools, aside from the 'normal' stuff, got a kreg jig and also biscuit joiner available.
Ranger 12
Ironlight 01-03-2012 02:10 PM
If it were me I'd use barrel nuts and bolts but I suppose if you're not going to put anything heavy on them then you can probably get away with screwing them on the sides of the cabinet from inside the 24" cabinet so you have no holes showing.
Just Bill 01-04-2012 06:35 AM
And to the wall, if there is a stud there.
ranger12 01-04-2012 08:47 AM
I built the house about 10 years ago, and had the good sense to put blocking in where we mught hang stuff later, including for cabs above the terlits, where this cabinet goes. Sure has made things easier as I finally get around to these things.
