Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 02-14-2008, 02:01 PM   #16
How serious is this mold?
Originally Posted by redline View Post
Is this drywall or plaster?
Being built in the late 40's, it would be plaster. If that were the case, the surface mold would just need to be wiped off with a chlorine/water mixture. It would be odd if moisture permeated the plaster and did no damage to the wall.
An easy way to check would be to scope the walls in a few spots. You can cut a hole the size of a pencil diameter and insert this scope into the wall cavity. It has a light on the end of a fiber optic 36" wand the bends.
I use one to do inspections for problems just like this.
Ron
Old 02-14-2008, 10:07 PM   #17
I had mold all over my plaster and lathe walls. It was pretty bad. It all has to come down. Then I got to put up all new insulation and drywall. :-(
Tdoggy187 is offline   Reply With Quote
Mold in detached garage jkrodger Building & Construction 15 05-01-2009 02:46 PM
mold problem, illegal? elementx440 Remodeling 6 04-09-2007 07:41 PM
