How To Self Level A Garage Floor & Step? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-25-2011, 07:49 PM   #1
Rewards Points: 27
How to self level a garage floor & step?
Hi all,
I have posted a pic below - I have a step up at the rear of my garage, and there is some upheaval of the concrete. I am guessing that the roots from the 60 foot pine tree I had removed from just outside the garage back wall was the culprit.
So, I was wondering - can I put some timber on the front edge of the step and pour a self leveling compound to smooth things out?
Any advice is appreciated.
Hugh
hugh71158 is offline   Reply With Quote
Old 01-25-2011, 08:12 PM   #2
Rewards Points: 6,652
Need a better shot showing more, than just the macro shot you took. If you really want to know, the only way to fix would be to rent a Jackhammer, or get someone with a bobcat to rip it out, and pour a new slab in your Garage.
Old 01-25-2011, 11:30 PM   #3
Rewards Points: 27
It's that bad? The image is the step up at the rear of the garage, I had been thinking about some sort of topping to level it all out, then a stain. Bad idea?
Hugh
Old 01-26-2011, 05:08 AM   #4
DIY staff
Rewards Points: 7,174
Self leveling compounds are soft and not intended to be a finished surface---used under tile--
Any thin cement layer will eventually pop loose in Michigans winters.---Sorry.--Mike--
Old 01-26-2011, 03:42 PM   #5
Rewards Points: 27
Ah, I see.
Hmmm, then that back step might become a candidate for a plywood floor. I have fully insulated the walls and ceiling of this garage so I want the floor to be a comfortable surface to stand on.
If it wasn't for the car I would lay ply on the whole garage!
Thanks a lot.
Hugh
The Following User Says Thank You to hugh71158 For This Useful Post:
oh'mike (01-26-2011)
Attached Garage, No sub panel, seperate grounding rod danocars Electrical 6 03-15-2010 05:27 PM
Garage Ventilation Question eagle09tbl HVAC 5 10-22-2009 09:24 PM
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 10:39 PM
Garage framing rotted, back side dropped 3" zetti1102 Building & Construction 12 08-06-2009 08:18 PM
Mold in detached garage jkrodger Building & Construction 15 05-01-2009 01:46 PM
