How To Seal A Real Granite Counter Top ?- Moved From Granite Transormations. - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-23-2008, 02:38 PM   #1
How to seal a real granite counter top ?- Moved from Granite Transormations.
Could someone describe the process of sealing a granite countertop? How long does it take? How often should it be done? Where is the sealant sold - available from stores like Lowe's or Home Depot?
Klavisha is offline   Reply With Quote
Old 02-24-2008, 09:20 AM   #2
Rewards Points: 5,326
You clean off the top with acetone first. Apply the sealer with any method you like. Brush, rag, paper towel. Allow it to sit on the counter as per the directions and wipe off the residue when directed.
As there are different formulations of sealer, pick one and stay with it. It can be purchased at the Borgs or any tile store.
Since all granites are not the same, application intervals vary. A minimum of twice a year would be safe for most stones. More if you like.
Ron
Corian or Granite counter tops Jms92 General DIY Discussions 21 04-17-2010 07:18 PM
granite counter maintence sflamedic General DIY Discussions 2 01-01-2008 09:19 PM
Remove Granite Counter tjsmadison Building & Construction 5 11-18-2007 02:13 PM
Granite tile counter question ryguy Flooring 3 09-27-2007 12:31 PM
granite counter top cutting trifit1 Remodeling 2 02-12-2006 07:56 PM
