How To Seal Grout - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-21-2009, 06:42 PM   #1
How to seal grout
What do you folks use to seal grout?
What special tools are needed?
How often should I do it?
mopowers is offline   Reply With Quote
Old 07-21-2009, 07:02 PM   #2
One way is to buy grout sealer and brush it on the grout.It is that simple. If you have a tile supply store in your area they can probably sell you everything you need and tell you how to do it. You can get everything at a big box but you will get beter product and expertise at a tile supply house.
beerdog is offline   Reply With Quote
Old 07-21-2009, 09:25 PM   #3
Rewards Points: 264
beerdog is giving good advice about going to a supply house. Dupont makes a line of products called StoneTech that get good reviews on John Bridge.
7echo is offline   Reply With Quote
Old 07-21-2009, 09:26 PM   #4
I like to use sponge brushes to apply grout sealer, just a personal preference. Time periods between sealing will vary depending on the product you use and the exposure of the grout. Check the label.
Chevy85 is offline   Reply With Quote
seal a polished marble bathroom floor? tarheelblue Flooring 21 01-12-2012 11:58 AM
Sealing grout for outdoor granite sidewalk TVM Tiling, ceramics, marble 17 02-16-2009 07:09 PM
Bleach then seal grout? Bacardi 151 Flooring 1 11-29-2008 10:23 AM
Tinting/re-coloring grout proofer Flooring 7 02-02-2008 10:59 PM
Do Tile setters seal grout? Yeti Flooring 2 10-24-2007 05:18 PM
