How To Replace Vinyl Siding - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-01-2013, 05:34 PM   #1
Rewards Points: 590
How to replace vinyl siding
I have a bunch of small random holes in my vinyl siding. Some are from the old deck where the builder decided to screw boards righ through the vinyl. Some are mystery holes that have been there since I bought the house. Can I remove middle pieces of siding without removing every piece above or below it first?
Here's one hole, as you can see I don't think my house has any paper between the siding and the wood which is why I want to just replace the few pieces with holes.
nikeman is offline   Reply With Quote
Old 06-01-2013, 05:48 PM   #2
Rewards Points: 13,300
First I would see if I could find a match.
Yours is a simple D-4 or D-5 which just means Double 4 or 5" exposure.
The trick is to try to match the brand.
I'd go to HD and Lowes since there close to your house and get one of there small sample they hand out for free. What you want to look for is the grain pattern.
Some companys look like cedar, some look like flat sawn pine.
The way those houses where built in your area I'd guess they used the least expencive .040 siding they could.
Just need a flat bar and one of there to take it off and replace it.
http://homerepair.about.com/od/exter...ng_ziptool.htm
Should take no more then 5 min to remove and replace each panel.
If some need to be cut a pair of tin snips will work in a pinch or a plywood blade on backwards on a ciruler saw will also work.
Old 06-01-2013, 06:13 PM   #3
Rewards Points: 590
Joe! Come build me some gates. Offer still stands. No rush at this point.
Old 06-01-2013, 08:08 PM   #4
Rewards Points: 2,634
If you go to YouTube, you can find some videos on how to replace siding.
SPS-1 is offline   Reply With Quote
Old 06-05-2013, 08:09 AM   #5
Yes, you can replace siding, but for that find out the brand used. It will be easier then to replace and find a suitable one.
leenamark1 is offline   Reply With Quote
Old 06-05-2013, 08:26 AM   #6
Depending on how lucky you are sometimed if you remove a piece all the info is printed on the back side of the siding on the heam.
Old 06-05-2013, 08:31 AM   #7
Rewards Points: 1,442
Is their grass near the holes? Maybe a lawnmower kicked up a rock and sent it through the siding. Not helpful, I know, but maybe solves the mystery.
mikegp is offline   Reply With Quote
Vinyl siding over lap siding thunderhead Carpentry 5 06-08-2011 11:56 PM
Mixture of Siding Material (Vinyl and Wood) jburr827 Building & Construction 2 05-19-2011 09:38 AM
New windows and new vinyl siding Fisher252 Building & Construction 11 05-09-2011 12:17 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
