Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 08-22-2012, 05:07 AM   #1
How to repair Storm Door
I purchased a Emco Storm Door from Home Depot few years ago. Unfortunately, the wind blew it open so hard that it ripped the screws out of the door. After that, the door would not close properly.
I removed the door to see the damage and noticed that the screws split the chipwood. How can I repair the wood so that I'm able to screw the door back onto the hinges?
Any help would be greatly appreciated. Thanks.
grgryl is offline   Reply With Quote
Old 08-22-2012, 07:40 AM   #2
Moderator
kwikfishron's Avatar
If you own a pile of bar clamps a repair is possible, otherwise the door is trashed.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is offline   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
grgryl (08-24-2012)
Old 08-22-2012, 10:36 PM   #3
How do I use the bar clamps to repair the wood?
Old 08-22-2012, 10:43 PM   #4
It's really not worth fixing.
Partacal board does not hold screws well when it's new, gluing it back together at best will be a temperary fix.
The reason it failed is no one probaly installed a safety chain at the top of the door.
About a $4.00 part.
http://www.bing.com/images/search?q=...55C97C&first=1
grgryl (08-24-2012)
Old 08-23-2012, 10:42 AM   #5
AHH, SPANS!!!
you might could get by with some glue and longer screws that penetrate deeper into the side of the door more and grab better...
hand drive is offline   Reply With Quote
The Following User Says Thank You to hand drive For This Useful Post:
grgryl (08-24-2012)
Old 08-23-2012, 11:40 AM   #6
In a little over my head
I think I'd try filling the crack with waterproof wood glue. Then sandwich the door between two 2x4s. Maybe use some wax paper so you don't glue the 2x4s to the door. Then clamp the 2x4s with as many clamps as you can find. At least 6. Use longer screws to reattach the hinge, pre-drilled. It might work. If it doesn't, you're only out the cost of the glue. You needed the clamps anyway.
ratherbefishing is offline   Reply With Quote
The Following User Says Thank You to ratherbefishing For This Useful Post:
grgryl (08-24-2012)
Old 08-24-2012, 08:57 AM   #7
PoleCat's Avatar
That sounds like it just might work. I'd try it.
PoleCat is offline   Reply With Quote
The Following User Says Thank You to PoleCat For This Useful Post:
grgryl (08-24-2012)
Special mounting needed for storm door darsunt Building & Construction 2 04-17-2012 02:38 PM
How to repair a door that taped striped off the finish? sofakng Windows and Doors 2 12-06-2011 09:21 AM
storm door clearance to eave edge 4just1don Building & Construction 4 10-20-2011 10:45 AM
Storm door mounting area - one side (jamb) is smaller than the other. joe_p Windows and Doors 4 04-07-2011 03:26 PM
Basic screen door vs full storm door. Jim F Remodeling 6 03-25-2011 01:10 AM
