-   -   How to repair Storm Door (http://www.diychatroom.com/f2/how-repair-storm-door-154441/)
grgryl 08-22-2012 04:07 AM
2 Attachment(s)
I purchased a Emco Storm Door from Home Depot few years ago. Unfortunately, the wind blew it open so hard that it ripped the screws out of the door. After that, the door would not close properly.
I removed the door to see the damage and noticed that the screws split the chipwood. How can I repair the wood so that I'm able to screw the door back onto the hinges?
Any help would be greatly appreciated. Thanks.
kwikfishron 08-22-2012 06:40 AM
199 Attachment(s)
If you own a pile of bar clamps a repair is possible, otherwise the door is trashed.
grgryl 08-22-2012 09:36 PM
How do I use the bar clamps to repair the wood?
joecaption 08-22-2012 09:43 PM
It's really not worth fixing.
Partacal board does not hold screws well when it's new, gluing it back together at best will be a temperary fix.
The reason it failed is no one probaly installed a safety chain at the top of the door.
About a $4.00 part.
http://www.bing.com/images/search?q=...55C97C&first=1
hand drive 08-23-2012 09:42 AM
you might could get by with some glue and longer screws that penetrate deeper into the side of the door more and grab better...
ratherbefishing 08-23-2012 10:40 AM
I think I'd try filling the crack with waterproof wood glue. Then sandwich the door between two 2x4s. Maybe use some wax paper so you don't glue the 2x4s to the door. Then clamp the 2x4s with as many clamps as you can find. At least 6. Use longer screws to reattach the hinge, pre-drilled. It might work. If it doesn't, you're only out the cost of the glue. You needed the clamps anyway.
PoleCat 08-24-2012 07:57 AM
That sounds like it just might work. I'd try it.
