How To Repair A Sink Ripped Out The Wall! - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-09-2009, 01:47 PM   #1
Anyone Know How To Repair A Sink Ripped Out The Wall???
So I decide to lean on my sink ... wrong move for me! It tears out from the wall .. I just stood there not knowing what to do ... I turned out the water and put my sink on a chair ... The pipes seem to be fine but the metal piece that goes in my wall so the sink can balance on ... needs to go back in the wall and i dont know what to do!!
Any Ideas
How To Repair A Sink Ripped Out The Wall!-img_0198.jpg   How To Repair A Sink Ripped Out The Wall!-img_0199.jpg   How To Repair A Sink Ripped Out The Wall!-img_0200.jpg
ray0890 is offline   Reply With Quote
Old 06-09-2009, 02:19 PM   #2
Learning by Doing
Leah Frances's Avatar
Doh! Doh!
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 06-09-2009, 02:23 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
It looks like the support bracket was secured by some sort of drywall anchors or toggle bolts. Not the best way to secure it. You need to put some lag screws thru the bracket into the studs or blocking. The problem is the bracket will not line up with the studs, so you need to as a short piece of 2 x 6 lumber between the studs. This means opening the wall to secure the blocking with screws. What is on the other side of that wall? If it is drywall, I would cut out a piece of drywall, secure the 2 x 6 blocking in place and patch the hole. Now lag screw the bracket to the wall and re-install the sink. If acces to the other side is not possible, remove enough tile below the level of the sink to cut out the drywall and install the blocking. Patch the drywall and replace the tile. Re-install the sink. Good luck.
Old 06-09-2009, 08:57 PM   #4
Wow. That stinks.
I always wonder how those toilets bolted to the walls don't fall off like your sink did. 280 lbs of me sitting on them and I've never broke one yet!
KHouse75 is offline   Reply With Quote
Old 06-09-2009, 09:53 PM   #5
the Musigician
DangerMouse's Avatar
if it's not easy enough access behind that wall, i'd consider just getting larger toggle bolts,
hammering that bracket straight (if bent) and remounting it. rehang sink on bracket.
it should do the trick....
DM
Old 06-10-2009, 09:11 AM   #6
Rewards Points: 5,336
I can't see toggle bolts working anymore with that sort of blowout in the sheetrock. I'd go with opening the wall behind the sink and putting in 2x4 blocking. If you do it correctly, the sink should hide the work.
Ron
Old 06-10-2009, 09:27 AM   #7
the Musigician
hmmmm.... i'm still thinking how to fix it with the least amount of work/expense. how about this?
lightly blow/brush excess plaster dust, then place duct tape to close the opening.
cut 2 4"x4" squares of 1/4" plywood....
glue them to the openings with a goodly (use the whole dam tube! what the heck!) amount of PL construction adhesive, even filling the ripped out part.... (place a light weight against them to gently hold them in place) wait a day or two to allow it to get good and hard, drill holes in plywood, then remount bracket with toggles (i'd still recommend larger, even if you need to drill a larger hole in the bracket), and use PL to glue THAT to the wall as well, adding a shim to flush it, if necessary. wait another day and hang the sink. i'm thinking this will be more than strong enough, yes? most likely even stronger than it was before.
DM
Old 06-10-2009, 09:30 AM   #8
the Musigician
one quick question ray, didn't the drain break when it fell? hard to imagine it didn't!
DM
Old 06-12-2009, 04:13 PM   #9
Rewards Points: 562
there is a dangerous mouse hiding around EVERY corner!!
4just1don is offline   Reply With Quote
Old 06-12-2009, 04:17 PM   #10
the Musigician
what? you don't like my idea?
DM
Tags
bathroom , broken , ripped , sink , wall
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 10:18 AM
wall switch repair Code3 Electrical 2 12-27-2007 04:39 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
This is not a load-bearing wall, right? AllGoNoShow Building & Construction 4 01-07-2007 04:49 PM
