Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 06-05-2009, 10:07 AM   #1
How to repair floor joist when sistering is not an option
My 1951 house sits on a crawlspace. The floor joists were set within notches or pockets in the block foundation wall. Old water damage caused many of the joist ends to rot and decay within the pockets causing the the floor to sag and bounce. The rot exists mostly on the joist ends within these pockets - with good, solid wood for most of the length of the joist. I can't just sister the damaged joists, becasue the foundation wall pockets are only wide enough for a single joist. My options are 1) cut off the bad end of the joist, replace with goo0d wood and sandwich between wood or steel, 2) enlarge the pocket in the foundation wall to accept a second sister joist, 3) build piers and a ross beam a foot away from the foundation wall to support the joists. It all sounds ok on paper, but it's located in a crawlspace with maybe 32" or working height. Has anyone seen and fixed a similar problem? - jmagee3d
jmagee3d is offline   Reply With Quote
Old 06-05-2009, 03:12 PM   #2
I would enlarge the block pocket and line it with something like ice and water shield to keep moisture away and use a pressure treated joist.
Carraige bolt(1/2") the two together with construction adhesive in the middle.
32" is a massive crawlspace. Count yourself lucky.
Ron
Old 06-05-2009, 03:33 PM   #3
Is a pressure treated ledger under the joists an option? Bolted or lagged to the block, with p.t. blocking to prevent rotation. Be safe, G
GBR in WA is offline   Reply With Quote
Tags
fxing floor joists
More On This Topic
Repairing and preventing home wood rot is best done with an interior/exterior paintable and stainable wood filler. Keep wood from deteriorating with tips from a heating, ventilation and air conditioning (HVAC) certified technician in this free video on... Read More »
Pocket doors are a great invention, allowing home owners to close off a portion of their house or open up a room without dealing with the wasted space of a hanging door. Pocket doors are designed to slide into a hidden pocket and be unseen when open. But... Read More »
Remove rotted house wood by cleaning it with a wire brush and apply wood filler to the wood. Fill rotted wood with tips from a heating, ventilation and air conditioning (HVAC) certified technician in this free video on home repair. Read More »
Learn about texturing your wall before faux painting, in this free video. Read More »
If you are at a loss as to what to do with your keepsakes, handed down furniture, year books, children’s toys or holiday ornaments, you should look up and consider your attic. Homes used to be made with stairs that went to the attic. Here children... Read More »
AC repair am I being scammed 911 hurley0351 HVAC 55 05-18-2009 09:14 AM
Fire repair detroitguy66 Building & Construction 3 08-20-2008 06:49 AM
Choosing a Refrigerator based on Repair Value 1655graff Appliances 1 01-07-2008 03:23 PM
Ceiling Drywall Repair Question kennykenny Building & Construction 6 12-30-2007 10:18 AM
Edge of roof deteriorated, how to repair? (pics) diymonkey Roofing 3 06-23-2007 02:02 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
