How To Repair Drywall With Paper Ripped Off - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-03-2012, 06:31 PM   #1
how to repair drywall with paper ripped off
The towel bars in my bathroom were glued on to what I think was primed drywall. One of the holders was knocked loose and it tore off the white paper so the brown paper is visible underneath. My question is how do I repair that before gluing the towel bar end back on.
Bonliz is offline   Reply With Quote
Old 02-03-2012, 06:36 PM   #2
Rewards Points: 14,312
Thin layers of drywall compound and a 4" wide drywall knife.
It's going to take a min. of 3 coats to get it perfect. Sand it with a dry wall med. sanding sponge, prime and paint.
Go buy a differant paper holder the scews to the wall.
Old 02-03-2012, 06:38 PM   #3
Gymschu's Avatar
Rewards Points: 1,040
Buy some GUARDZ primer made especially for these types of issues. Apply the GUARDZ to the damaged area. Allow it to dry. Apply 2 to 3 coats of joint compound to the area, sanding between coats. Feather out your patch a little bit more each time you recoat. When you're satisfied that the patch is flush with the rest of the wall, do a final sanding to make sure it is smooth. Wipe of dust, apply a drywall primer to the patch, allow to dry, then recoat with whatever paint is currently on the wall.
The Following User Says Thank You to Gymschu For This Useful Post:
chrisn (02-04-2012)
Repair of drywall. Noticed bad insulation yardlady General DIY Discussions 3 09-04-2011 07:50 AM
Drywall repair Transmico Building & Construction 2 11-24-2010 06:17 AM
sanding into paper on drywall patch joseph2293 Drywall & Plaster 11 02-23-2010 08:53 PM
proper method for paper faced drywall corners rocketdoctor Drywall & Plaster 2 12-06-2009 10:14 AM
Frustrated by paper along side of drywall J187 Drywall & Plaster 6 04-22-2009 05:29 PM
