How To Remove Urine Smell From Concrete Floor - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-29-2009, 02:32 PM   #1
How to remove urine smell from concrete floor
I have an apt where the tenant apparently urinated on the carpet (it was soaked when we pulled it out and there were no animals in the apt). Anyhow, the floor is concrete underneath and before we put new tile down, we need to do something to get rid of the odor. We've already washed the concrete down with bleach and water and it still smells. Someone suggested painting concrete with Kiltz or Bin and someone else suggested using a grey "concrete sealer", like the type you'd put on a garage floor. Has anyone had any experiece with this? Any suggestions and reasoning re what approach is the best and least expensive?
Thanks! Jerolyn
jerbark is offline   Reply With Quote
Old 04-29-2009, 03:13 PM   #2
Licensed P.E./Home Insp
Aggie67's Avatar
Rewards Points: 818
No personal experience, but I saw this addressed on one of the DIY shows recently. Unfortunately I can't recall the show. I remember them treating the floor with something and then sealing it with paint. The urine left behind some salts that were causing the odor.
Aggie67 is offline   Reply With Quote
Old 04-29-2009, 03:16 PM   #3
Rewards Points: 346
Simple solution
Simple solution will get rid of the odor and any stain. I have used this on cement, wood, subfloor and carpet with complete success. Pour it on, let it soak in then leave it alone until it is dry. I find this much better then sealing in the odor and it works on vomit and that odor that hangs around when an animal dies. You can find it most pet stores or on Amazon if you can not get it locally.
http://www.amazon.com/Simple-Solutio...1032078&sr=8-1
Rege
RegeSullivan is online now   Reply With Quote
Old 04-29-2009, 08:26 PM   #4
Rewards Points: 95
I would not paint or seal if the tile going down is ceramic or anything being set with thinset. The paint or sealer will inhibit the bond.
NJ Brickie is offline   Reply With Quote
Old 04-29-2009, 09:50 PM   #5
Safe, Most of the Time!!
brokenknee's Avatar
Nature's miracle works pretty good, sold at pet stores.
I also saw the show Aggie was talking about, the previous owners had cats (I think) that used the basement for the bathroom. I remember they highlighted the soiled areas with a black light.
I do not remember what they used to clean it with; but I do remember the owners said the smell would get worse when the moisture was high.
"Clarity to Agreement" Dennis Prager
Picture/Photo Pitcher/Carafe ------- Where/Someplace Were/Be
brokenknee is offline   Reply With Quote
Old 04-29-2009, 10:04 PM   #6
brokenknee's Avatar
I think it was TSP tri sodium phosphate.
Old 04-29-2009, 10:33 PM   #7
Simple solution works good. it is designed specifically for removing pet odors and stains. you can get it at many pet stores.
beerdog is offline   Reply With Quote
Old 05-20-2009, 04:22 PM   #8
I have an old cat who sometimes misses her litter box, i have found cheap white vinegar is the best thing to kill the ammonia smell of urine.
vinegar actually chemically neutralizes ammonia.
DeFex is offline   Reply With Quote
Old 05-27-2009, 12:17 AM   #9
Borax is the ticket my friend. Taxidermist have used the stuff for many years to draw oders out of all kinds of fish and animals before mounting and drying out the skins.
It will draw that oder right out of there.
jordy3738 is offline   Reply With Quote
Is it ok to paint concrete floor in winter... dbldee20 Painting 2 02-06-2009 02:06 PM
Old Tile on Concrete floor bmenton Flooring 1 01-27-2009 07:53 PM
Best way to smooth concrete before putting down floor? Tommy2 Flooring 9 12-24-2008 09:15 AM
Very bumpy concrete floor that is not level cgcaudle Flooring 1 08-31-2008 05:04 PM
