-   General Discussion (http://www.diychatroom.com/f2/)
-   -   How to remove screw stuck in the wood? (http://www.diychatroom.com/f2/how-remove-screw-stuck-wood-148548/)
higv2000 06-28-2012 10:01 PM
While trying to remove the broken sliding door lock, a long screw inside the latch through the wood can't be removed -- it's stuck inside the wood. Plyers wouldn't go into such a small space; the screw head is also messed up -- could you help with ideas to remove this screw? What can I use to carve the screw head so that I can use my screw driver to unscrew it?
Wildie 06-28-2012 10:15 PM
How about a photo?
joecaption 06-28-2012 10:18 PM
Dremal tool with a cut off blade.
higv2000 06-28-2012 11:55 PM
1 Attachment(s)
Originally Posted by Wildie
How about a photo?
Here is the photo. Thanks for the help in advance.
Attachment 53206
higv2000 06-28-2012 11:57 PM
1 Attachment(s)
Here is the photo. You can see the screw I need to remove. Thanks for the help in advance.
Attachment 53207
joecaption 06-29-2012 12:00 AM
Looks like someone tryed to use the wrong sized screw driver to get it out.
A set like this will do one of two things get it out or drill off the head of the screw so the plate can be removed, then the screw should be loose in the hole.
http://www.sears.com/craftsman-6-pc-...&blockType=G11
Wildie 06-29-2012 12:04 AM
The head of the screw can be removed by drilling straight into the head with a drill bit that is the same diameter as is the shaft diameter of the screw. Just keep drilling in until the head pops off.
Once the latch assembly is removed, grab the shaft of the screw with needle nose vice grip pliers and turn it out.
miamicuse 06-29-2012 12:09 AM
Sometimes, if the screw is bitten hard into the metal as well, you can try rotating the latch itself counterclockwise, and see if the screw head moves with it. I have had a few times doing this backs the screw out just a tiny bit enough to back it out slowly.
You can also use a dremel tool with a thin cut wheel to crave out a deeper slot on the screw to use a flat head screw driver.
Or worse case scenerio a screw extractor.
All else fail use an angle grinder to grind off the screw head to remove the latch, then grind it flush with the wood, hopefully the new latch will have holes in a different spot.
higv2000 06-29-2012 12:09 AM
Thank you, Wilde and Joecaption -- will try that tomorrow.
joecaption 06-29-2012 12:18 AM
I've also had good luck with one of these.
It's made to be struck with a hammer and the bit turns as it's driven.
Not very expencive and comes with several differant bits.
Any auto supply should have one.
I used to use one all the time when I worked on motorcycles and it would pop out even the cheap soft screws they use.
epson 06-29-2012 12:21 AM
get yourself a screw extractor
http://ts1.mm.bing.net/images/thumbn...916f83b3ed45b9
http://ca.video.search.yahoo.com/vid...lk85br&newfp=1
gerardswork 06-30-2012 11:00 AM
Speaking from experience...
I encountered a similar "opportunity" and found a screw extractor to be the answer. I used this forum to figure it out, and you can see my challenges and successes here:http://www.diychatroom.com/f2/broken-off-bolt-145038/ For starters get the largest sized extractor possible...approximately $2.56 at HD.
Glad to help.
Gerard
jbfan 06-30-2012 01:33 PM
With that much of the screw exsopsed, a pair of vice grips will remove it.
Tom Struble 06-30-2012 02:40 PM
that is an andersen door latch and that screw is about 3'' long
try using a no.2 or 3 square drive,if they don't work you can pull the inside trim and cut it off where it passes thru the door then just pull it out
