How To Remove Drywall Mud/dust From Vinyl Floor - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-10-2013, 09:22 PM   #1
Rewards Points: 160
How to remove drywall mud/dust from vinyl floor
Was doing some mudding and sanding, cleaned up after and the vinyl floor (which is darker in color) has tiny white spots in the patterns indents of the flooring.
Washed it 4 times and when it dries, the white dots are still there...any ideas?
Cleaning with rag and water...
hellothere123 is offline   Reply With Quote
Old 11-10-2013, 11:27 PM   #2
Rewards Points: 324
A toothbrush and warm water worked for me. The bristles get down inside of the indentations.
For a large area, I wonder if there is some kind of gadget with a soft-bristle you could attach to your drill. Kind of like the round pads they use to clean or buff the paint on a car.
gma2rjc is offline   Reply With Quote
Old 11-11-2013, 12:33 AM   #3
Rewards Points: 197
Try a Mr. Clean Magic Eraser in a spot. If it seems like it might work they make a Magic Eraser mop head. I've only seen it at Big Lots but it works wonders on dirty vinyl.
Arlo is offline   Reply With Quote
Old 11-11-2013, 06:24 AM   #4
Rewards Points: 13,228
Prevention is the cure.
When hand sanding drywall open a window and remove the screen and set a cheap dollar store box fan in the window.
Have a shop vac running and sand with one hand and hold the hose in the other.
Shut down the HVAC system while sanding.
I use a Rigid brand vac and have bought an extra hose that I attach to the exhaust that gets hung out a window and use the drywall bags inside the tank over the filter.
Drywall dust needs to be shop vacuumed up. As soon as water hits it your stuck with a muddy mess.
Old 11-11-2013, 06:33 AM   #5
Not so new
12penny's Avatar
Rewards Points: 520
^ +1. vacuum is the way to go. To late now though. Once you add water, it turns back into compound.
12penny is offline   Reply With Quote
Old 11-11-2013, 07:28 AM   #6
PoleCat's Avatar
Rewards Points: 1,646
Regular soft broom lots of water and a wet vac.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 11-11-2013, 08:14 AM   #7
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 38
Use a damp sponge on the wall instead of sandpaper next time.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
The Following User Says Thank You to rusty baker For This Useful Post:
gma2rjc (11-11-2013)
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 02:37 PM
Vinyl floor tiles on vinyl floor Project423 Flooring 2 02-27-2012 02:04 PM
Have this sheet vinyl floor asbestos tested? CoconutPete General DIY Discussions 11 01-21-2012 11:39 PM
want to remove recent vinyl flooring over asbestos subfloor fabster Flooring 5 05-04-2011 02:59 PM
Asbestos in old vinyl floor taubel Flooring 3 08-19-2010 09:48 PM
