Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 10-10-2009, 08:31 PM   #1
Default How to put backer board on top of the tub
Should the backer board come over the lip of the tub and come down all the way on top of the tub? Also how far should the tile come down on the tub?
snessmith is offline   Reply With Quote
Old 10-10-2009, 09:45 PM   #2
Default Backer to the top of the tub
Before you install your 1/2 inch backer,Please make sure that the studs are tight to the tub.
If not sister up new studs and make sure the wall is flat.
The backer board rests on the top edge of the tub.
The gap is filled with mastic or firmset as you tile.
You will bring the tile within 1/8 inch of the top of the tub.
A good silicone caulk applied after grouting will finish the tub tile joint.
I have never seen a level tub,Do your layout so that you have a cut tile at the tub top.Trying to start at the top of the tub will not work.--MIKE
More On This Topic
The base of your mosaic is determined by your application. Since this mosaic is a kitchen splash, I decided to put the mosaic on the backer board that you put tile on to put a splash on a kitchen. And this is what the backer board looks like. You buy it... Read More »
We're going to go into more detail on how to use tools later, but as a basic overview on what tools you'll need to make your tile mosaic project, you're going to need a tack hammer to break your tiles with. Also as I mentioned before, gloves and glasses... Read More »
I’m now going to transfer my design onto the backing material. And so on this backer board I placed a piece of carbon paper and then I placed my design onto that. And made sure my edges are lined up. And then I trace around the design like so. Make... Read More »
Using Mosaic Tile Grout
Using Mosaic Tile Grout by Expert Village
You'll find grout at any hardware store. You'll find sanded and non-sanded grout. Sanded grout is good for almost every mosaic project. The theory is, as long as your grout joints are more than a quarter inch apart, then you'll want to use sanded grout... Read More »
Hi! This is Steven Keilholz Flooring on behalf of Expertvillage.com and today I am going to show you the materials you need to install a ceramic floor in your basement. The first thing you need is a good drill with a good mixing paddle. The heavier the... Read More »
installing backer board over particle board bob mac Flooring 5 06-15-2009 07:01 PM
Hardie backer board DXS General Discussion 2 03-17-2009 07:40 PM
best way to fasten backer board? ponch37300 Flooring 17 01-06-2009 02:59 PM
How Do I Patch Tile Backer Board? rajrae Tiling, ceramics, marble 1 11-17-2008 11:43 PM
Painting DensShield tile backer board warriorfox Painting 2 05-15-2008 06:08 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
