How to plug unwanted and leaking conduit?
2 Attachment(s)
I have an old conduit going through my concrete foundation, about 1 foot underground. It's roughly 1 inch diameter, some sort of poly pipe. It used to have a couple of copper lines running to an underground oil tank. The oil tank was removed a long time ago, but the lines were just cut and bent over. Water has been leaking in through the conduit (not around it) every time we get a big rain. Today I dug down to the conduit to look into plugging it from the outside. I've removed the copper lines and now have a 1" conduit to nowhere in my foundation that I need to plug. What is the best way to plug this thing? The conduit is about 14" long going through a 12" wall. A local box hardware store guy said I need to pull out the conduit and plug the hole with "Quikrete Hydraulic Water Stop" and to even burn out the old conduit if I had to. Then I talked with another guy at the same store, and he said that I probably won't be able to get the conduit out, and that I should fill it up with an expanding foam, and seal the outside end with some sort of caulking. I thought I would just buy some sort of two part epoxy and fill it up, but I guess thats the wrong idea? I've enclosed a picture of the inside and the outside. I live in New Hampshire USA, so it does get cold here in the winter if that makes a difference... ?
http://www.diychatroom.com/attachmen...1&d=1281227752 http://www.diychatroom.com/attachmen...1&d=1281227764 |
Cut off flush, or use a cap & cement on there. If have to use a chisel to make a recessed spot to take the hydro when you pack it, you will have to. Remember, that if you use a torch, it will be worst, than either capping with a cap & filling with Hydro Cement.
If you could put a cap over it too, that would make it even better. |
You can buy ABS pipe caps at any building center.
On the outside, clean the ABS off, and then glue the ABS cap in place. Simple and cheap!:wink: |
I would still fill it with spray foam. it will ensure that it's sealed and insulate it too so you don't have to worry about condensation.
I'd run another outdoor outlet
I always need more :santa: |
| All times are GMT -4. The time now is 02:52 AM. |
