Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 05-29-2008, 11:03 AM   #1
How much does a 5/8 drywall board cost???
Hi all...i know this is a dumb question, but i can't find an answer online. How much does a 5/8 drywall board cost??? Also, how much would a 5/8 board of sheetrock cost.
I don't know what size they are generally sold in...so please indicate the dimensions as well as the price.
THANKS SO MUCH!!
bswain06 is offline   Reply With Quote
Old 05-29-2008, 11:22 AM   #2
Moderator
Termite's Avatar
Drywall and sheetrock are the same thing. Sheetrock is actually a name brand of drywall.
They come in 4x8, 4x9, and 4x10, plus longer sizes at some suppliers.
Off the top of my head, I'd plan to pay just under $10 for a 4x8x5/8" sheet. In residential, 1/2" is used for most walls and 5/8" is more common on garages and ceilings.
Old 05-29-2008, 11:29 AM   #3
Great! That's just what i needed. thanks for answering my rather dumb question.
Old 05-29-2008, 11:49 AM   #4
K&B Remodeler/Tile Guy
angus242's Avatar
Well I'm confused about your question but here it goes....
wallboard, drywall and gypsum are essentially all the same thing.
1/2" is the most common thickness and comes in sheets sized:
4x8
4x9
4x10
4x12
5/8" is generally used for ceilings in some application, as a fire rated material in other (assemblies...see I remembered kctermite!) and in high end homes as the actual wall material.
Cost will vary all over the place. The last time I bought 4x8x1/2 it was just under $7 a sheet.
EDIT:
and apparently I was slow in replying cuz when I hit the "reply" button, there weren't any responses. Sorry for what's essentially a double post....
Angus
angus242 is offline   Reply With Quote
Old 05-29-2008, 12:12 PM   #5
Depends on what your looking for you have basic 1/2 sheet rock which is about 8-9 a sheet and the you have the mold/mildew resistant stuff about 10-11 and then you have mold/mildew and fire resistant which is about 12 a sheet
anc001 is offline   Reply With Quote
Old 05-29-2008, 12:52 PM   #6
Moderator
Termite's Avatar
Nah, just confirming that the OP's getting good info!!!
Old 05-29-2008, 12:54 PM   #7
I'm pricing 1/2" rock for our basement and as of yesterday at Menards here it's $4.99 for a 4x8' sheet. $5.68 at Home Depot for the same stuff. Can you do a ceiling in 1/2" if you just use more fasteners?
perpetual98 is offline   Reply With Quote
Old 05-29-2008, 02:10 PM   #8
Moderator
Termite's Avatar
Good prices! I paid about $7/sheet for 1/2" here a couple weeks ago.
You can use 1/2" on ceilings, but you're better off with 5/8" in my opinion.
With either thickness, you must space screws no further apart than 12" and nails no further apart than 7" for ceiling applications.
Old 05-29-2008, 07:56 PM   #9
Drywall and Painting Pro
Sir MixAlot's Avatar
If your ceilings are 24" on center, 5/8" drywall is recomended. Or 1/2" ceiling board.
Checkout some of
Sir MixAlot is offline   Reply With Quote
Old 05-29-2008, 09:13 PM   #10
I'm going to be furring my ceiling out, and unless something comes up, I'll be furring 16" OC. I can get 5/8", that's really not an issue, so I'll probably go that route, at least for the ceiling.
Old 05-29-2008, 09:16 PM   #11
Average Joe/ex-Navy IC3
gregzoll's Avatar
Depends on the Market area. On the average around $9.00.
Old 05-31-2008, 11:59 AM   #12
Advice worth 2 cents!
I just finished my home....everyone is really impressed with my walls. I did all the work myself (135 sheets). The secret?
5/8" rock!!!!!!
and using no-coat in the corners. (www.no-coat.com)
- pete
---pete
HandyPete is offline   Reply With Quote
Old 05-31-2008, 12:12 PM   #13
angus242's Avatar
Just came back from the store:
4x8x1/2: $4.98
4x8x5/8: $7.15
DensArmor 4x8x1/2: $10.98
Angus
Old 08-15-2008, 12:56 AM   #14
Well poor us here Kamloops, BC Canada :
Home Depot : 5/8 $17
Home Hardware 5/8 $16
Just about twice what you pay accross the border!
kingrene is offline   Reply With Quote
Old 08-16-2008, 10:02 AM   #15
Geeezz! Sorry Kamloops, here in Québec it's about 9$ for 1/2" and 11$ for 5/8"
---pete
Cost to Drywall hang/finish...please read, good explanation Firehawk734 Remodeling 63 12-17-2012 10:29 PM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 11:05 AM
Cement Board and Drywall Champy Remodeling 2 01-24-2008 04:32 PM
Drywall Taping Cost loosegroove Building & Construction 10 10-22-2007 06:41 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
