How To Mount Hose Reel To Brick - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-09-2009, 01:40 AM   #1
How to mount hose reel to brick
Hello,
I'm needing some info on how to mount this to the side of my home (brick). Is it better to drill the mounting screw into the brick or the mortar? Is it relatively difficult getting one of these installed?
Thanks in advance
rrussou812 is offline   Reply With Quote
Old 03-09-2009, 06:56 AM   #2
Tapcon screws(concrete screws) work well for this, if the proper size hole is drilled. Correct size drill bits often come with, or are available where the screws are sold. It is usually easier to drill into mortar joints with a standard drill. Driling brick sometimes requires a hammer drill. Be careful not to try to overtighten the screws, once they strip out they are useless.
Old 03-09-2009, 08:52 AM   #3
the Musigician
DangerMouse's Avatar
i'd think mortar would pull out easier than the brick, no?
if you add a plastic anchor to the hole before the screw, it'd probably help too?
DM
Old 03-09-2009, 11:12 AM   #4
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
I too like the tapcon approach. The mortar is easier to drill into and the tapcons wont pull out unless you over tighten them or the hole is too big.
The way I like to do this project is to mount a board first to the brick. Paint it, make it look nice, then attach the hose reel to that. The advantage is hole placement. its likely the holes in the hose reel wont line up to where you want to drill. Mount the hose reel with wood screws to the board.
Good luck
Brik is offline   Reply With Quote
Old 03-09-2009, 12:52 PM   #5
concretemasonry's Avatar
Rewards Points: 2,578
One thing about Tapcons - When stripped, they are always not a total loss and a scar.
If you strip them, you may have the alternate to enlarge to hole in the mortar and use a plastic or lead anchor for the screw. If you drill into a hard brick, you run the risk of cracking the brick when the screw causes expansion (not as likely with softer brick).
Dick
concretemasonry is online now   Reply With Quote
Old 03-09-2009, 03:35 PM   #6
Tapcons are the easiest way
Tapcons have plenty of holding value for your application. Most people with your application use a 1/4 x 1 3/4 hex washer head Tapcon. Be sure that the concrete screw gets into the brick at least 1" but no more than 1 3/4". If the tapcon passes the maxinum embedment of 1 3/4" the hex head may sheer off. The correct drill bit for this concrete screw is the 3/16 x 4 1/2. Be sure to clean the hole out before you drive the tapcon and its very important to drill the hole with a hammer drill. You can save some money if you buy the tapcons online instead of at your local big box store.
Bronx is offline   Reply With Quote
Old 03-09-2009, 05:39 PM   #7
Good advise if you have to drill into the brick.
Just avoid drilling into hard brick because they are brittle and you may not develop much pull-out resistance.
20 year old Brick Wall Repair Bobrobert General DIY Discussions 15 11-22-2011 04:07 PM
Sealing historic brick tenzo General DIY Discussions 2 11-22-2008 04:04 PM
Mounting Hose Reel on Stucco Siding xquercus General DIY Discussions 5 07-03-2008 01:00 AM
garden hose water spillage questions mcvane Landscaping & Lawn Care 10 07-29-2007 01:27 AM
