How To Loosen Soft Metal Faucet Assembly Without Scratching Metal - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-24-2014, 10:18 AM   #1
Rewards Points: 55
How to loosen soft metal faucet assembly without scratching metal
I need to remove the handle from my bathroom sink faucet in order to replace the ceramic disc cartridge. My problem -- I cannot figure our how to grip the faucet assembly with a wrench in order to loosen the assembly without scratching the soft metal.
This problem is best illustrated with the two attached pictures.
Any suggestions? Thank you.
How to loosen soft metal faucet assembly without scratching metal-bathroom-sink-faucet-pic-1.jpg   How to loosen soft metal faucet assembly without scratching metal-bathroom-sink-faucet-pic-2.jpg
goshenplumber is offline   Reply With Quote
Old 01-24-2014, 08:05 PM   #2
Rewards Points: 276
Does that handle really loosen that way, or is there a nut underneath that turns to loosen it?
Jim F is offline   Reply With Quote
Old 01-24-2014, 08:18 PM   #3
Rewards Points: 144
Check for a small set screw at the base of the handle.
mako1 is offline   Reply With Quote
Old 01-25-2014, 05:30 AM   #4
DIY staff
Rewards Points: 7,174
A good rubber strap wrench usually works for me----
VIPlumber (01-26-2014)
Old 01-25-2014, 05:33 AM   #5
Rewards Points: 5,974
The handle has to come off first.
Old 01-25-2014, 11:16 AM   #6
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 2,990
+1
Strap wrenches are pretty effective if the strap is really clean.
The Following User Says Thank You to Windows on Wash For This Useful Post:
oh'mike (01-26-2014)
installing tub faucet without scratching marble tile tsayles Plumbing 2 04-09-2013 09:16 PM
Why can't you connect Ground/Neutral bus bars on a sub secutanudu Electrical 42 11-07-2012 01:33 PM
Metal Carport Cover Assembly bforrest13 Building & Construction 0 07-09-2011 09:15 AM
adding new sink / faucet / drain assembly... and I'm clueless :-( diy'er on LI Plumbing 4 11-13-2009 05:36 PM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 08:46 PM
