How Long Will It Stand - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-29-2013, 10:37 AM   #1
Lord of Slums
Rewards Points: 1,974
How long will it stand
http://imgur.com/a/Y3pwR I worry this deck will hurt someone, I found the pictures online and do not know the person. I am fearful that this deck will pull from the wall and hurt someone. Never mind the 4x4 posts, those foundation blocks are dangerous, to say the least.
mj12 is offline   Reply With Quote
Old 04-29-2013, 10:56 AM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,816
I'm willing to bet that it will last a lot longer than you think.
Yea...the big issue is the blocks....but I don't see the thing collapsing and killing a bunch of people...instead, it will start to sag....and at some point someone will point out the issues and they will fix it.
In the meantime....lets go over there and enjoy the party...free food and booz
ddawg16 is online now   Reply With Quote
Old 04-29-2013, 11:36 AM   #3
Rewards Points: 2,238
Concrete blocks?!?
That's a good foundation!
Don't see no braces on the 4 X 4's?!?
"House of cards"?!?
rossfingal is offline   Reply With Quote
Old 04-29-2013, 12:02 PM   #4
JOATMON
ddawg16's Avatar
Originally Posted by rossfingal View Post
Concrete blocks?!?
"House of cards"?!?
Look how they did those 4x4's....they go up and are part of the guard rail.
Because it's anchored against the house....the absence of cross bracing is not a bad is it could be.
Would I do it that way? No.....but I've also seen a lot worse.
Old 04-29-2013, 01:00 PM   #5
r0ckstarr's Avatar
Rewards Points: 2,052
Look at the last picture. It looks like they made a little bit of support for the concrete overhang where the deck meets the house. Look closely. It looks like that 4x4 is under the concrete overhang and not the deck.
r0ckstarr is offline   Reply With Quote
Old 04-29-2013, 01:13 PM   #6
Rewards Points: 150
What are you all saying is so bad?
Posts extending up to become part of the railing - is that a problem? I thought that's normal. If not, why not?
Cross bracing is missing? Where? Are you talking diagonal bracing on the posts to prevent a scissoring sort of collapse? I don't see that's possible being affixed to the house in two directions.
Footings... If those aren't poured with post bases set into them, I think that's a problem. But that's all I spotted. Otherwise I think it looks good.
-mike
SquishyBall is offline   Reply With Quote
Old 04-29-2013, 01:26 PM   #7
Rewards Points: 736
You just found a random set of pictures of a deck on the Internet and decided to worry about it? Can you even imagine how many unsafe structures there are out there? Why worry about some stranger who isn't asking for your help or input?
TheBobmanNH is offline   Reply With Quote
Old 04-29-2013, 02:29 PM   #8
All we were doing was making some comments on something, someone
constructed.
I don't seem to see, too many bolts or joist-hangers -
Is that a problem?!?
Not bad for 1 and 1/2 days of work -
If you want to do it wrong!!
(Bet there was no permit! - Ya think?!?)
Ha, ha, ha!
(I hope with the success of this experience - they don't move on to multi-story decks! -I don't think that's a "concrete"
over-hang/cantilever)
Old 04-29-2013, 02:35 PM   #9
Rewards Points: 258
can't see it in this picture but ther is a 2x4 nailed to the 4x4 to suport the over hang and its not concrete. they had what looks like particale board for the deck on the covered section
redman88 is offline   Reply With Quote
Old 04-29-2013, 02:43 PM   #10
Registered User
Rewards Points: 5,514
I agree, it was poorly constructed to not pass minimum prescriptive code for decks; http://www.awc.org/Publications/DCA/DCA6/DCA6-09.pdf
1/2 the loads for new deck are on old cantilevered house joists, all posts are wrong attachment to beams, beams are single member- doubles required, no post bases to concrete, concrete not required depth to below frost line, footings within 5' of house same depth as house footings, over-spanned "beams" for loads, joist hangers missing, ledgers/brick attachment not per code, picket spacing and lower rail spacing/deck over 4" maximum, handrail under 36" minimum height, house corner windows now require safety glazed, not mentioning the screendoor hinge placement...
Gary
Old 04-29-2013, 02:57 PM   #11
Jessh! - Gary!
So critical!?!
Looks "cute" - don't it?!?
The Following User Says Thank You to rossfingal For This Useful Post:
Gary in WA (05-01-2013)
would this Rectangle sink and stand go together? mxl180 Remodeling 5 07-28-2011 07:41 AM
Tool stand recommendation Ranger1227 Tools 5 05-16-2011 08:37 PM
Why long lasting bulbs go out of service quickly? art2670 Electrical 8 10-27-2009 08:10 AM
Miter-saw stand 2creeks Tools 5 09-03-2008 09:53 PM
Need help building a 2 layer stand for aquarium/snake cage Biggredd Building & Construction 5 02-13-2007 11:10 PM
