How To Keep A Trim Piece On The Ceiling? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-29-2013, 10:14 AM   #1
Rewards Points: 578
How to keep a trim piece on the ceiling?
Just a quick question. How do i get these trim pieces to stay on the ceiling? Ive stapled them with two lengths of staples, ive liquid nailed them, i dont want to use normal nails or screws because they would be immediatley obvious. I dont know what to do, every time i try something, i come back the next day and the thing is laying on the floor again! Please help me!
Come and see the progress on my mobile home paradise!!! (NEW PICS ADDED ON 01/26/15!!)
http://www.diychatroom.com/f49/compl...emodel-168570/
TrailerParadise is offline   Reply With Quote
Old 01-29-2013, 10:19 AM   #2
Rewards Points: 3,130
In most trailers I've seen, the trim was held up by small screws with plastic rosettes to make them more decorative.
Old 01-29-2013, 10:24 AM   #3
Rewards Points: 578
the other pieces are held up with brad nails, but no electric = no brad nailer. No rosettes in this trailer. the ceiling panels are glued up i suppose.there are staples and brad nails along the edges but nothing in the middle.
Old 01-29-2013, 10:30 AM   #4
I would use adhesive. The type would be based upon the material, but I have had good luck with gorilla glue or similar.
oberkc is offline   Reply With Quote
Old 01-29-2013, 10:39 AM   #5
Rewards Points: 578
ive had good luck with gorilla wood glue when building cabinets, but it doesnt want to stick here. The materials are the trim is made of 1/4" paneling, cut in strips and bradnailed to the ceiling. The ceiling is made of hardboard, painted white and with a grainy texture that is super annoying to work with. nothing wants to stick to it. Even liquid nails let go.
Old 01-29-2013, 10:41 AM   #6
Rewards Points: 14,306
Got to have to hit the studs, going to need long finish nails.
DO not use gorilla glue! That's will just make a mess.
Might want to try Loc Tite Power Grab.
http://www.loctiteproducts.com/p/12/...n-Adhesive.htm
Old 01-29-2013, 10:53 AM   #7
Rewards Points: 117
when you glued it, did you put a piece of lumber under it to press it against the ceiling until it dries enough for you to remove the lumber?
if not perhaps try wedging a 2x4 in there to hold it up
echobravo is offline   Reply With Quote
Old 01-29-2013, 11:01 AM   #8
Rewards Points: 578
i wedged my bifold doors up against it to keep it there, they are the only thing i have that is tall enough. ill try the Loctite and see if i can find some brown finish nails, i cant use silver because it will show.
Old 01-29-2013, 11:09 AM   #9
Not going to happen, just use use a nail set and a dab of matching wood filler.
Plaster ceiling with peeling paint annaem Painting 14 01-19-2012 12:10 PM
What to do with this old ceiling? mudworm Building & Construction 4 07-17-2011 04:54 PM
Sagging ceiling timbo59 Drywall & Plaster 8 07-02-2010 12:15 PM
Installing ceiling trim with uneven ceiling. capslock Carpentry 3 03-20-2010 11:53 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
