How To Install Mailbox To Metal Post - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-25-2015, 05:54 AM   #1
Rewards Points: 97
how to install mailbox to metal post
the post is metal and the flat part that the mailbox will sit on, has holes in it. I have a new mailbox that is standard and needs to be attached to a piece of wood. I see now that the current lousy mailbox is being held on by some kind of metal wire run in between the mailbox and the wood and then tied around the post - not sturdy.
SpaceCoast is offline   Reply With Quote
Old 04-25-2015, 06:40 AM   #2
Rewards Points: 2,862
If your standard box is like the ones we country folks have, using the holes in the metal, attach a 1- x - xx - x - xx piece of wood to the metal plate. The recess on the under side of the box will determine the xx dimensions. The lower sides of the box are then screwed to the 1x edge with non rusting screws.
http://www.budgetmailboxes.com/salsb...mailboxes.html
The Following User Says Thank You to SeniorSitizen For This Useful Post:
joecaption (04-25-2015)
Old 04-25-2015, 07:49 AM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 4,326
I bolt the mailbox directly to the flat plate on the post drilling new holes in the bottom of the box if those on the plate do not align already.
nap is online now   Reply With Quote
Mailbox post slyguysmoke1 Landscaping & Lawn Care 9 01-01-2015 08:12 PM
Reuse Concrete Fence Post Pier & Fence Post Extraction JasonCA Landscaping & Lawn Care 2 03-24-2012 08:58 PM
How do you install this metal edge on the wall? noone Tiling, ceramics, marble 2 12-15-2011 12:03 PM
install ceiling fan in a suspended metal stud ceiling? amp3d Remodeling 2 09-10-2010 07:55 PM
Hardwood and Metal Post Problem! moonweb Flooring 13 07-02-2008 03:12 PM
