How To Install Bike Hangers - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-19-2008, 10:40 AM   #1
How to install bike hangers
I'm trying to install bike hooks (hangers) to the ceiling in my garage. The ones I bought look like the one in the picture (attachment). I'm wondering how I can screw it in since it is not something I can attach to a drill. Even if I make a pilot drill little smaller than the thickness of the screw, it woul still be a pain to screw the bike hook with bare hands.
Any suggestions?
Thanks!
slinku2020 is offline   Reply With Quote
Old 11-19-2008, 10:52 AM   #2
Drill a bigger hole. They shouldn't be too hard to screw in. If you need to, stick a pole through the hoop to give more leverage.
jerryh3 is offline   Reply With Quote
Old 11-19-2008, 11:03 AM   #3
RippySkippy's Avatar
The pilot hole should be just smaller than the diameter of the shank not the threaded portion. You should be able to use your hands to screw it in, you'll have a fair amount of leverage when you twist on the larger hook end.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 11-19-2008, 01:10 PM   #4
A little lubricant like soap or wax on the threads should make turning easier.
Handyman Jim Noonan is offline   Reply With Quote
Old 11-19-2008, 02:03 PM   #5
I generally like wax (candle, paraffin bar, etc) as some soaps can be corrosive to metal.
LMASD
Old 11-19-2008, 10:06 PM   #6
Rewards Points: 562
A box end wrench looped over the tang and wrench shaft on back side of question mark shaped piece gives you lots of leverage. It should screw a bit hard to stay up there. For crying out loud make SURE its screwed into wood,,,studs, or joists,,,plain drywall wont hold sickem!!
4just1don is offline   Reply With Quote
Old 11-20-2008, 09:05 AM   #7
Thank you all. I will try it this weekend. I have two bikes to hang.. so it will be lot of wax and twisting, I suppose.
Old 11-20-2008, 09:07 AM   #8
unless you live in an old house with old growth lumber, it won't be that difficult...MAYBE a 15 minute job, look at all the other things you can do when you're done!
LMASD
Old 11-20-2008, 09:21 AM   #9
Enormous Member
skipjack's Avatar
Rewards Points: 87
I've installed many of these since I'm an avid biker and an avid home buyer.
The hook portion itself gives you plenty of leverage to screw into the pilot hole.
skipjack is offline   Reply With Quote
Old 11-20-2008, 11:13 AM   #10
RDS
Rewards Points: 150
Agreed. I did this recently with those very hooks, into a very old beam. With the right-sized predrilled hole it's not at all hard. If getting leverage while reaching over your head is a challenge for you, stand on something sturdy.
RDS is offline   Reply With Quote
Old 11-24-2008, 03:45 PM   #11
Didn't think it would be this easy. I pre-drilled a hold just the right size and it wasn't difficult screwing it all it, of course it got harder as I got to the end, but that's a good sign.
Done with drilling, screwing and putting up 2 bikes in about 30 minutes.
Thanks all!!
Old 11-24-2008, 04:35 PM   #12
Congrats! What did you do with the rest of your weekend? "We" told you.......
LMASD
Anyone install a tin/copper style ceiling? flashme18 Remodeling 7 07-19-2009 07:56 AM
When to install tile flooring? MT Stringer Remodeling 4 10-28-2008 08:49 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 10:42 AM
How to fit joist hangers on "swollen" joists drh Building & Construction 2 02-21-2008 11:20 PM
Joist Hangers handy man88 Building & Construction 1 10-28-2007 10:12 PM
