How To Hide Pressure Reg. - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-27-2010, 01:47 PM   #1
Rewards Points: 79
how to hide pressure reg.
In the finished part of my basement, my main water line comes in. There is a shut off valve and a water pressure regulator in the wall. The previous owners built a box around it. Is there another way to hide this but still have access? Maybe something that would look better than what I have now?
AndyH24 is offline   Reply With Quote
Old 12-27-2010, 02:17 PM   #2
Hiding in plain sight?
Hanging a picture over it was the first thing that came to my mind.
I have a furnace door in my hall. I took the molding off then textured and painted the door just like the walls. Not very noticeable.
Hope this helps.
Rustedbird is offline   Reply With Quote
Old 12-27-2010, 02:29 PM   #3
Rewards Points: 22
I would first remove the trim, regardless; it's too obtrusive, even if it were cut square. After that, since the drywall is probably rough around the opening, I would square up the rough opening, and finish it with a corner bead, and then tack in some stops for a flush, painted, plywood panel, or, depending on your taste, simply hang a flag, macrame, picture, or surface mount shadow box over it. If you wanted to be creative, you could even build a flush shadow box, with mirrors or pictures set in line with the wall where the regulator and pipes don't allow for anything of depth.
Old 12-27-2010, 09:10 PM   #4
You could place a full length mirror in front of it!
Then, if there's a pipe rupture somewhere in the house, someone can runaround looking for the shut-off while the house gets flooded!
Old 12-28-2010, 09:09 AM   #5
Rewards Points: 5,336
Princess and the pea.
Ron
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 11:43 AM
Boiler pressure troubles jduffett HVAC 2 12-12-2010 08:15 AM
Intermittent Low Water Pressure Fox Plumbing 4 03-02-2010 07:04 AM
Pressure Switch, Draft Inducer, Burner Box, Problem majorapus HVAC 7 10-25-2009 07:14 PM
New Pressure Switch -- low water pressure chach Plumbing 4 01-18-2009 10:50 PM
