How To Hang Something On Siding? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-02-2011, 09:39 AM   #1
Custom User Title
Rewards Points: 252
How to hang something on siding?
I have a wrought iron star that I need to hang on the gable of my house. The gable has vinyl siding on it currently. What is the best way to hang it? It is fairly heavy.
no1hustler is offline   Reply With Quote
Old 06-02-2011, 12:43 PM   #2
Rewards Points: 2,238
Find the studs inside the gable - hit them with your fasteners.
The "rule of thumb" for fastening through Vinyl siding is - pre-drill the
siding - 3 to 4 times the thickness of the fastener.
We would caulk the holes with some type of urethane/poly-urethane
caulk - "Quad", "Solar-Seal", etc...
Tighten the fasteners "snug"; but, not "dead tight" - expansion.
Probably, use galvanized screws.
rossfingal
rossfingal is offline   Reply With Quote
Old 06-02-2011, 03:27 PM   #3
Custom User Title
Rewards Points: 252
Any way to do it without drilling through the siding? I'm guessing not.
Old 06-02-2011, 03:43 PM   #4
Vinyl siding expands and contracts quite a lot.
You should pre-drill it.
The siding itself, will support VERY little.
If the siding "oil-cans", buckles, distorts ... because it's "locked" in place -
even if you remove what's preventing it from expanding/contracting -
the damage is done - time to replace it.
rossfingal
Old 06-03-2011, 07:54 AM   #5
Custom User Title
Rewards Points: 252
Thanks for the help!
Old 06-03-2011, 08:36 AM   #6
No problem!
Good luck!
rossfingal
vinyl siding over asbestos?? Buckeyes97 Remodeling 12 08-21-2012 10:20 PM
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 11:07 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
