How To Grout Uneven Tile Mosaics? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-20-2010, 12:31 PM   #1
How to grout uneven tile mosaics?
Hi all, I am trying the "mosaic garden sphere project" on DIY. I have discovered that mirror glass and ceramic tile have differing heights and how am I going to grout it without covering up the mirror glass?
lindad5 is offline   Reply With Quote
Old 02-21-2010, 06:49 AM   #2
Clean as you would any grout job, but maybe a bit of special attention to the low tiles. If there is a large difference in height, you did not set them right.
Old 02-21-2010, 07:13 AM   #3
How to set different heights of glass/tile?
Ok how would you set different heights of glass/tile so that they will be the same height?
Old 02-21-2010, 08:48 AM   #4
Rewards Points: 192
We put some tumbled slate (i believe) up in our kitchen as a backsplash. The tiles are uneven and not level all the way across. That is how they are designed; wasn't an installer (me) issue.
I considered the job not the standard tiling job because of all the nooks and crannies on the tile itself. It was a lot of finger-work and not your usual tooling. I believe I used a float to push the grout in the joints, but I do know there was a lot of cleaning of the tiles because of the grout.
After everything was dry, I picked up some kind of cleaner from Lowes. I forget what it was called, but it had something to do with removing grout from tiles. I carefully went tile by tile and scrubbed them clean with the stuff. After that and everything was washed, I sealed them.
The end result looks really nice, but it was a pain and it did take a couple of weekends to get it done. I'd say that when you grout, just be prepared to use a lot of water and keep changing the bucket to make sure it's clean water.
wiz561 is offline   Reply With Quote
Old 02-21-2010, 09:23 AM   #5
Rewards Points: 5,336
It depends on how much of a difference exists. If it's a small difference, say 1/8", I would just place an additional layer of thinset down and let it dry. Then tile the thinner mosaics to the level of the tile next to it.
I wouldn't do it all at one time as the thinset might ooze up between the tiles more easily.
Ron
Tags
grout , mosaics
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Uneven grout color homeownertexas Kitchen & Bath Remodeling 4 10-20-2009 12:50 PM
Uneven grout color homeownertexas Building & Construction 3 10-20-2009 07:06 AM
Cracking floor grout - Ceramic tile DeepDish Building & Construction 9 08-27-2008 09:51 PM
Cracking floor grout - Ceramic tile DeepDish Flooring 9 03-03-2007 07:49 PM
