How To Fix A Pot Light Coming Out Of The Ceiling - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-18-2009, 02:43 PM   #1
How to fix a pot light coming out of the ceiling
I was trying to remove the trip when I guess I accidentally pulled the whole housing out of the ceiling. I can remove the release clamps onthe side (not sure if this is the right term) and pull the entire unit out (ie. not fixed to the ceiling). The clamps look like springs. Basically, I think the releasing clamps should be holding the housing unit up but it won't. Any ideas of how to fix this?
http://img194.imageshack.us/img194/7218/picture115v.jpg
xcell is offline   Reply With Quote
Old 07-18-2009, 06:01 PM   #2
Rewards Points: 5,336
To remove the trim, you first remove the bulb.
For a Halo remodel fixture:
Look up into the housing to see if you see 2 wires going from the trim to a plate above the socket.
Remove both wires and the trim will be disconnected.
There will be 4 black spring clamps that will need to be disengaged to remove the can or re=engaged to secure the can.
Push the can up to the ceiling and slide the clips up to clamp the sheetrock. Sometimes you can do it by hand, other times you need a screwdriver.
Reinsert the trim and put the bulb back.
Atlite will require a different scenario.
Ron
Old 07-18-2009, 06:13 PM   #3
actually this unit only has 2 silver spring clamps that look like those springs in clothes pins (except longer). there's nothing inthe ceiling. this unit comes entirely out and the based on the unit there are two heavy cables (ie. metal surrounds the wires) attached. that's why im trying tofigure out that is holding this too the ceiling...i think it's just the metal spring clamps.
Old 07-18-2009, 11:07 PM   #4
Try to find a manufacturers label on the unit and go to their website for the installation directions.
Ron
Old 07-22-2009, 11:04 AM   #5
Rewards Points: 338
xcell, Halo high hats, aka recessed lights, come in two flavors; old work (for installation after the sheet rock/wall board is up) and new work (installed before the sheet rock/wall board goes up). If you can pull the can down some and look into the ceiling, new work cans have a metal frame that looks as if it's sitting on the ceiling, old work have (or should have) four black clips. They are shaped like an arch, one end has a "foot" and the other a "tee". They fit into a cross shaped hole on the side of the can with the foot outside the can. When installing them, all the clips should be hanging inside the can. Push it back into the ceiling, press the tee of the clip upwards. It should go all the way to the top. The new work cans (Halo) have four screws that hold the can onto the frame. Other types of cans have three or four tabs that stick slightly out from the frame and apply pressure to hold it in place. Hoped this helped. pete
petey_c is offline   Reply With Quote
Separate Single Pole Switches for Ceiling Fan Light and Fan Only estatehomes Electrical 19 01-13-2012 07:13 PM
Adding Ceiling Light From Switched Outlet vboz5 General DIY Discussions 2 03-04-2009 01:53 PM
Connecting a Ceiling fan to a Light Switch AceAvenue Electrical 6 06-03-2008 04:06 PM
Ceiling light abuse! shurik57 Electrical 5 11-26-2007 11:30 AM
heavy ceiling light suspension amakarevic Building & Construction 1 07-01-2007 08:32 PM
