Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 06-10-2009, 04:08 PM   #1
how to fix loose swimming pool tiles
i'm a new army widow and need good advise how to fix pool tiles that have fallen off inside pool wall mostly above the water but would be exposed to water.
i tried the homedepot/lowes and pool stores and they didn't seem to know or care
i appreciate any guidance
also, i read the tutorial but it didn't say what "tags" purpose is for , if you read this could you inform me
thanks
Frankenhauser is offline   Reply With Quote
Old 06-13-2009, 11:19 AM   #2
first make sure that the back of the ile is clean - secound make sure that the wall where you are reatching the tile is in good shape (still solid). There are a few product that you can use to put the tile back on. The least expensive is "POOL PUTTY" this is an epoxy product that will hardden above or below water. when first mixed it is verry simular to clay it will the get rock hard. the other product is an adhesive sealant such as Aqua bond, this is more expensive and requiers that you buy a gun and mixing tips to use this product.
sninny is offline   Reply With Quote
swimming pool enclosure grendon Building & Construction 15 09-01-2012 03:28 AM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Wiring for swimming pool heater and salt system Scooby Electrical 1 06-08-2009 12:59 PM
Swimming Pool Converted To Fish Pond ghall79 General Discussion 6 05-23-2008 12:11 PM
Swimming Pool Water pilotandy72 General Discussion 4 07-31-2007 11:04 AM
