How To Fix A Leak From The Ceiling ? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-26-2011, 10:00 AM   #1
How to fix a leak from the ceiling ?
Hey guys. Our family has a problem every it rains hard our room experiences a bad leak. How can we fix this?
Zielle is offline   Reply With Quote
Old 05-26-2011, 10:48 AM   #2
Rewards Points: 6,652
Find out where it is leaking on the roof. How long ago did the roof get replaced.
Old 05-26-2011, 12:36 PM   #3
Rewards Points: 1,092
How can you fix WHAT? You'll need to go up on the roof and see exactly what is leaking. Do you have shingles that blew off? Is there a crack around a roof penetration? Have nails in steel roofing popped up? Etc.
Old 05-28-2011, 12:54 PM   #4
Tizzer's Avatar
Rewards Points: 470
Best to hurry up and fix where ever the leak is, even if just temporary. Waiting will invite mold and/or the ceiling falling apart.
If you can't spot the leak from up in the attic, hire someone.
Tizzer is offline   Reply With Quote
Old 05-29-2011, 05:57 AM   #5
Too Short? Cut it Again!
Check anything flashed on the roof to see if it or the seals have failed. Chimney, vents, etc.
Hope you don't have a flat roof. Chasing down leaks in them suckers can take a lifetime.
And indeed, resolve this sooner rather than later. It and complications mentioned will only get worse.
Old 05-29-2011, 06:39 AM   #6
NACE Coating Inspector
mustangmike3789's Avatar
blue tarps must work good. my neighbor has had them on his house for years. they look really nice too! if possible, get in the attic and look for water marks.
mustangmike3789 is offline   Reply With Quote
Old 05-29-2011, 07:26 AM   #7
waterman1971's Avatar
Rewards Points: 154
That is too funny!!
Thank God for fema!
waterman1971 is offline   Reply With Quote
Old 05-30-2011, 10:54 PM   #8
If your room is leaking during a hard rain and you have a fireplace, good chance rain is blowing in under your siding on the chimney. Need to give more information on the house and where the leak is.
pnarron is offline   Reply With Quote
Tags
leaks
Ceiling issue wooten General DIY Discussions 5 06-06-2011 07:20 PM
Leak coming from air vent in ceiling when hose is on... callmedpit Plumbing 0 05-22-2011 09:16 PM
Roof leak nightmare..... it won't stop amandat37 Roofing/Siding 52 04-22-2011 12:47 PM
Level 5 finish expectations? Cracked ceiling.....input needed please! HeatherJ Drywall & Plaster 6 01-14-2011 05:04 PM
Ceiling Repairs and Muresco Paint: Seamless Paint Job Possible? Lovegasoline Painting 4 11-25-2009 02:06 PM
