Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 01-14-2009, 08:56 AM   #1
Unhappy
How do you stop cigarette smoke coming through walls?
We've just bought a terrace house (built 1966), with a chain smoker next door. We can't stop her cigarette smoke from coming in, both in the lounge room (has gas fire in fireplace) and the main bedroom (no fireplace, but is above the lounge, so has chimney inside a built in wardrobe). The smoke is so bad that we can see it around the light fittings - and all of our clothes smell too. The smoke is definately not coming in the windows or via the loft.
I have to assume that there is a brick wall between the two houses (otherwise it is totally not safe from a fire perspective, but we can only see plasterboard and wallpaper on our side. (There is a lined built-in wardrobe in the bedroom, which is why the clothes are so affected, I suppose).
Is there some product we can use to stop the smoke from entering? A sealant? Some special sort of plasterboard or insulation? I don't think that the neighbour is interested in stopping smoking. We have to do something, as my asthma is getting worse, unfortunately, and our eyes sting all of the time now. It has to be coming in either the walls or the chimney.
Advice please!
ACTed is offline   Reply With Quote
Old 01-14-2009, 01:49 PM   #2
Remodeling Contractor
add foam insulation pads to all electrical devices on the shared wall. Caulk along the floor and ceiling and any other wall penetrations. It is possible that the attic is shared. Look into this. It should be completely sealed to conform to fire codes. If it is not, get someone to fix it. Write letters, so when your place burns down from the idiot next store, you know who to sue. If they do not fix this area, you will also need to apply the same treatment to any ceiling penetrations.
Old 01-15-2009, 05:55 AM   #3
I would suggest air cleaners such as the ones from Oreck. I suffer from allergies and have two units in my house in Southern California. In the wild fires we have experienced the past years the outside air was thick with smoke - my neighbors homes reaked of the smoke smell afterwards - but mine did not. I was cleaning my air cleaners several times a day vs. normal of every few days - further evidence they were clearing the air.
http://www.oreck.com/air-purifiers/x...ers_choice.cfm
Do not get HEPA filters with replacable elements - they do not do as good a job and require frequent replacement of costly filter elements.
Old 01-19-2009, 06:28 PM   #4
The separation is a "fire separation wall" by code. That doesn't mean it is or that it was built properly. I know from personal experience that keeping the builder honest is difficult even if he is honest and impossible if he isn't. You bought a lemon and it will always stink. Sorry.
unoga is offline   Reply With Quote
Tags
cigarette smoke
More On This Topic
Hi, I'm Bobby on behalf of Expert Village. Everyone loves having a warm fireplace on a cold winter day. The downside to that is that you have to clean the fireplace. In this series we are going to show you how to clean the inside of your fireplace, your... Read More »
Many outdoor fireplaces are fancier than indoor ones. Some expensive fireplaces stand over eight feet tall and include MP3 docks. Less fancy ones are just a metal bowl with legs. Almost anyone can afford an outdoor fireplace because there are many styles... Read More »
The efficiency of a fireplace depends on several factors. Though the design is certainly important, it isn't the only thing to consider. Adding components and performing routine maintenance are critical to maximizing efficiency. No matter what type of... Read More »
Hi, I'm Bobby on behalf of Expert Village. Everyone loves having a warm fireplace on a cold winter day. The downside to that is that you have to clean the fireplace. In this series we are going to tell you how to clean the inside of your fireplace, your... Read More »
How to Clean a Chimney
How to Clean a Chimney by Expert Village
Hi, I'm Bobby on behalf of Expert Village. Everyone loves having a warm fireplace om a cold water day. The downside to that is you have to clean the fireplace. In this series we are going to tell you how to clean the inside of your fireplace, your... Read More »
help -black smoke coming out of chimney after furnace service schmolze HVAC 9 11-14-2008 05:54 PM
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 09:39 AM
Keeping Water out of the Top of Brick Walls o2barockstar Roofing 4 02-18-2008 03:50 PM
Question about Cigarette moke and AC venting jtnippon HVAC 2 08-28-2007 01:03 AM
Smoke on walls in kitchen diylady Painting 7 07-14-2007 11:09 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
