How Do You Remove Stripped Screws? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-24-2012, 10:45 AM   #1
how do you remove stripped screws?
How do you remove stripped screws? the ones in the door handle on an exterior door. used to be phillips head, now square. How to remove them? Square bits do not work
firsttimeremode is offline   Reply With Quote
Old 09-24-2012, 10:52 AM   #2
the Musigician
DangerMouse's Avatar
I've always found a Dremel tool to be the fastest way to remove stripped screws. Just cut a slot in the screw and use a flathead screwdriver.
DM
The Following User Says Thank You to DangerMouse For This Useful Post:
mae-ling (09-24-2012)
Old 09-24-2012, 10:54 AM   #3
good idea! I never even thought about that. Thanks!
Old 09-24-2012, 10:56 AM   #4
you can try permatex (http://www.autozone.com/autozone/acc...pound/_/N-2592) to see if you can take the largest slot screwdriver, apply the compound to the screw then lightly hammer in and twist.
otherwise, try one of these back out tools
http://www.amazon.com/Alden-8440P-Gr..._bxgy_hi_img_z
allthumbsdiy is offline   Reply With Quote
Old 09-24-2012, 11:19 AM   #5
i think ill try the Dremel first, since i already own one, and if it doesnt work ill try your suggestions
Old 09-24-2012, 11:21 AM   #6
Rewards Points: 150
Someone just recommended to be to try a rubber band as well. Never got a chance to try it, but sounds like it might be a free option to try before hitting the store.
knotquiteawake is offline   Reply With Quote
Old 09-24-2012, 07:19 PM   #7
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Stripped screw remover kit.
They do work, when used as directed (follow the instructions carefully).
Example Link: http://howto.homedepot.com/videos/wa...w-Remover.html
- Build Well -
The Following User Says Thank You to AtlanticWBConst. For This Useful Post:
Old 09-26-2012, 10:33 AM   #8
Okay problem solved. I tried all of your suggestions, and none of them worked. The remover kit drilled in sideways because of the bulbous handle, it would not drill straight. The Dremel saw just threw sparks everywhere and did not even touch the screw. Permatex didnt work, it just came right off the screw. So eventually i had had enough and i opened the door, got an iron bar, and brought it down on the handle with as much force as i could. Popped right off. I didnt want to do that because i wanted to donate the handle to Restore but oh well. The rest came out with a screwdriver and hammer, and the new one went in easy as pie. The real problem was the strikeplate, the old one was held in with rivets. Since i dont have a drill bit, i had to use my Dremel saw to cut the rivet heads off and pull it off. At least it shuts and locks now. We had several people pull on the other side, the only way someone is getting through that door is to take the wall out.
Old 09-26-2012, 02:58 PM   #9
keep your eyes open for that back out tool during the upcoming black friday sale.
i picked up a craftsman 3 piece set for 5 bucks few years ago. it is one of those tools you will have laying around most of the time, but it is very handy.
good luck with your remodel.
Old 09-26-2012, 03:02 PM   #10
i used the backout tool. It didnt work. thanks for the suggestion though.
Old 09-26-2012, 04:15 PM   #11
Too bad you didn't try the elastic band. Sometimes the simplest solution is overlooked.
It has worked for me numerous times
creeper is offline   Reply With Quote
Old 09-26-2012, 04:34 PM   #12
i did try a rubber band, i just didnt put it in that paragraph. It worked for a couple of seconds, then it started turning instead of the screw. Doesnt matter now, the doorknob has been killed. Unusable.
Old 09-26-2012, 05:05 PM   #13
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
i drill out the head with a 1/4 " or 3/8 bit then grab the shank with small vice grips then turn it that way
woodworkbykirk is offline   Reply With Quote
Old 09-27-2012, 03:31 PM   #14
I've had good luck with using a Dremel to cut a slot, but you have to use a cutting wheel, not a saw or metal blade. Using vice grips also works well if there's enough of the screw head sticking out to get a grip with the pliers.
rchorse is offline   Reply With Quote
Old 09-27-2012, 03:48 PM   #15
Bombastic Idiot
notmrjohn's Avatar
Always been my tool of choice, when nothing else works, hit it with a hammer. If that don't work, get a bigger hammer.
First seems to really be goin at with that trailer, maybe she needs an entire forum of her own.
Measure twice, cut once.
Look at the nail, not the hammer. Watch the fence, not the blade.
If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
notmrjohn is offline   Reply With Quote
Composite vs wood deck screws cranedk Building & Construction 6 11-26-2015 04:47 PM
pocket hole jointery and cabinet screws for framing newbymodeler Carpentry 29 03-07-2013 04:17 PM
how do I remove paint from hinge screws? Msfrmtx Painting 17 12-11-2012 09:41 AM
Cut Off Stripped or Broken Screws mdawson3k General DIY Discussions 23 07-26-2011 08:07 AM
Stripped screws in chair Paul McMullin Carpentry 4 04-06-2010 03:41 PM
