Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 08-06-2007, 10:15 PM   #1
How do you insulate an old stone basement?
In the winter I can put my hand against it and feel cold air flowing in! I am trying to prep now for this winter.
Thanks!!!
hydepark is offline   Reply With Quote
Old 08-06-2007, 10:44 PM   #2
fierysun's Avatar
I was looking at foil insulation for my attic. They mention basements on the uses link below. For my purposes I was looking at the Prodex foil foam foil product. Hope it helps a bit.
http://www.insulation4less.com/highr_uses.asp
Trying to keep all my fingers and toes
fierysun is offline   Reply With Quote
Old 08-07-2007, 07:23 AM   #3
Thanks fierysun. I'll look into it further. Any other ideas anyone? My basement is from the 1870's and it consists of large stobe boulders that are by no means flat. The space inbetween is filled with mortar, but it's old and leaky. Is there a spray that will for a "candy shell" over these stones to insulate?
Old 08-07-2007, 12:57 PM   #4
Tired, Cold, and Damp
slickshift's Avatar
No quick and easy insulation for these sorry
One of the best ways would be to UGL them up and frame and drywall and insulate some walls
Obviously not a quick project, but it's extremely effective
I suppose just the UGL and some loose or sheet insulation over that would help
But it's going to be a patch up looking job, and not nearly as effective as the walls
The "Pink" insulation company has some new wall products for refinishing/insulating basement walls
As far as I know it won't work on these stones, but it might be worth checking out
slickshift is offline   Reply With Quote
Old 08-07-2007, 01:55 PM   #5
Custom Cabinet Maker
Hyde : called fieldstone foundation I got one and nope aint insulated
Only way I can think of is to frame walls in front and insulate them.
JackM
skymaster is offline   Reply With Quote
Old 08-07-2007, 02:00 PM   #6
Thanks Slick!
Old 08-08-2007, 09:35 AM   #7
Hyde, I have lived in two such houses, one as a child (mother still lives there) and one as an adult. If you want to spend the money, the best solution is to have the mortar patched and/or replaced from the outside. If you are looking for a cheap, but seriously ugly fix, straw bales around the foundation will block a lot of the air leakage. A former neighbor of mine also used foam insulation boards with expanding foam on his (outside) but it doesn't last long and is about as ugly as the straw bales. Consult with a professional basement repair person before framing in the walls in the basement. A lot of these old homes have moisture problems, especially if you have stone floors too. Good luck!
Keyo77 is offline   Reply With Quote
Necessary to insulate basement ceiling between joists? yummy mummy Building & Construction 12 02-07-2009 12:19 AM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 10:09 AM
Sub Basement Walkout - Please Help pgs_28 Building & Construction 11 08-12-2007 10:55 PM
Where to insulate in basement...? DIY4EVER Building & Construction 5 07-27-2007 01:33 PM
How to 'start' finishing the basement... mcvane Building & Construction 18 06-04-2007 09:28 AM
