How Do You Enclose Open Plan Stairs? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-30-2013, 09:29 AM   #1
How do you enclose open plan stairs?
Hi,
I was just wondering if anyone could give me some ideas. I have an open plan stair case that I want to enclose. Is it an easy job? what sort of wood should i use? what should I cover the back of the stairs up with? Has anyone done this to their own stairs? just looking for some ideas as i'm not the best at DIY lol
How do you enclose open plan stairs?-sam_1010.jpg   How do you enclose open plan stairs?-sam_1012.jpg   How do you enclose open plan stairs?-sam_1014.jpg
Billbo128 is offline   Reply With Quote
Old 04-30-2013, 10:01 AM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
Just a thought, unless you install risers also you will have a dirt catcher with the back enclosed. There are so many different materials you can use to enclose the back with, it would be a matter of your preference. Most use sheet rock to enclose the back as it is also a fire stop.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
Billbo128 (04-30-2013)
Old 04-30-2013, 10:06 AM   #3
Rewards Points: 150
What kind of plan do you have in mind for the space under the stairs? Are you going to have it be a diagonal ceiling? How far down will the diagonal go before you cut to vertical? Or will it be all enclosed and turned into a closet? I always like the pic on the minwax home page (www.minwax.com) when it comes to enclosed undersides of stairs. That looks really nice. Also go to www.houzz.com and search for stairs -- you'll find tons of inspiration.
SquishyBall is offline   Reply With Quote
The Following User Says Thank You to SquishyBall For This Useful Post:
Old 04-30-2013, 10:13 AM   #4
Rewards Points: 2,238
Probably, should use 5/8" Type-X, drywall on the underside of the stairs.
Some type of risers, for sure.
The railings would not pass code around here.
(Neither would the stairs!)
If you're going to add risers; and, you're going to paint them -
you could use decent 1 X pine - think about some type of glue -
as well as nails/screws.
We would use Oak.
"RF"
rossfingal is offline   Reply With Quote
The Following User Says Thank You to rossfingal For This Useful Post:
Old 04-30-2013, 10:00 PM   #5
Old School
Willie T's Avatar
What a rare opportunity you're sitting on! Strip those treads, and maybe the stringers too, and refinish them to be the centerpiece of the house. Open stairs cost a fortune to have built.
They could even be fully wrapped with carpet for the lazy way out.
Of course to become code compliant, you're going to have to consider some sort of risers. Maybe two or three horizontal chrome bars, to help keep the "open" effect? 1/2"? Or plexiglas or Lexan? Maybe "tinted"? And change out the railing for one with attractive baulsters and a code compliant handrail... 2x's like that are not only tacky, but dangerous because they afford very poor gripping shapes.
But PLEASE consider alternatives before boxing-in what could become a stunning focal point of your home.
Willie T
Old 04-30-2013, 10:15 PM   #6
Msradell's Avatar
Rewards Points: 90
A little clarification is needed. Do you want to make them look like a conventional stairway by installing risers or do you just want to put a flat sheet of material on the back to prevent items from falling through? These 2 jobs are very different in approach, cost and code compliance. If you want to install risers to make it look like a conventional stairway, the 1st question would be what is the relationship of the front of one step to the back of the one below it? We would also need to know the dimensions of each tread to give you a good answer.
Msradell is offline   Reply With Quote
Old 05-01-2013, 08:03 AM   #7
PoleCat's Avatar
Rewards Points: 1,646
Our basement stairs look exactly like yours. I was going to put risers on but noticed that my toe would encroach this area during normal use and would really go deep when hauling a load. I did not like the idea of a dirt trap just tacked to the bottom so they remain open there. The cat digs it that way too. I did remove the old 2X4 railing and put up sides though. I had plenty of 2X2 on hand so I framed from the stairs to joists so the underneath storage would not be interrupted.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Encloseing open plan stair jomac Carpentry 4 04-07-2013 09:50 AM
How to plan for attic ventilation for central air when modifying gable vents? Ocelaris Roofing/Siding 13 03-21-2013 09:50 AM
Questions about building stairs. cvriv.charles Building & Construction 7 12-19-2012 05:04 PM
Create an open office at the Top of the Stairs? floodj32 Remodeling 1 01-08-2012 03:50 PM
Creating Open Floor Plan kevin327 Building & Construction 2 12-18-2010 01:10 PM
