How Do You Cool This Room Without Expensive A/C? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-12-2009, 02:49 AM   #1
How do you cool this room without expensive A/C?
I live in so cal and every year around this time I find myself in this situation. I live with family and the room I stay in has no vents for A/C. The house has a central A/C unit that pumps A/C into the main room but does not run through room to room.
The window I have is sideways so its tough to find an A/C unit that will fit right. I am kind of stuck. Anyone have any ideas on what I can get that won't cost an arm & a leg just to cool one room?
I have a fan in the window and its not really doing the trick and looks rather tacky.
Room size.
GT Motion is offline   Reply With Quote
Old 07-12-2009, 03:38 AM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Can you take out the burglar bars?
Disclaimer
& Stay Safe
.....Bob Lavery
Old 07-12-2009, 06:17 AM   #3
There are no burglar bars, what you see in the background are part of an overhang that starts almost 15 feet away from the window. There is a plant that is also back there. The window is free and clear.
Old 07-12-2009, 08:46 AM   #4
Rewards Points: 5,336
Get a window A/C and fill in the space with a sheet of plywood. Paint it to match the house. This is the cheapest option.
Ron
Old 07-12-2009, 08:50 AM   #5
the Musigician
DangerMouse's Avatar
????? just get a portable AC unit...
duct it out the window there or wherever.
DM
Old 07-12-2009, 05:49 PM   #6
+1 for the portable AC unit. Got mine on ebay for a pretty good price and it works great to cool one room. Some are heat pumps so it could provide heat when needed also.
Mike in Arkansas is offline   Reply With Quote
Old 07-12-2009, 06:07 PM   #7
Learning by Doing
Leah Frances's Avatar
They make A/C units for slider windows like that.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 07-12-2009, 08:31 PM   #8
How big is the room ?
Guide on sizing an AC for room size:
http://www.energystar.gov/index.cfm?...properly_sized
Old 07-12-2009, 11:15 PM   #9
Rewards Points: 27
I live in northern California, towards the north end of the Sacramento Valley. I use 18,000 BTU Window AC units (2) to cool my 1200 sq ft house.
You could get by with less than 18000 BTU for the one room. I was at a local Lowes store the other day and they had stacks of window AC on sale. I'd look for something that would run on 110V, 15A, and that'd probably be in the 15,000 BTU arena.
You can either cut a hole in the wall like I did, or if that's not ideal, then stuff it in the window and close it in with plywood.
Today's window AC units are really efficient. When it's 110F up here I can keep my entire house at 78F by running the two units on medium settings.
SeeDBee is offline   Reply With Quote
Old 07-13-2009, 10:28 AM   #10
All those stand alone AC units will drive you crazy with noise...what you need is a Mitsubishi air conditioner
JonM is offline   Reply With Quote
Old 07-13-2009, 07:59 PM   #11
Rewards Points: 264
JonM,
Mr. Slim is great, but way more money than a window or through the wall unit.
7echo is offline   Reply With Quote
Vents from boiler room RammsteinNicCage HVAC 3 03-11-2009 08:28 PM
A room in a room? artosie General DIY Discussions 2 03-10-2009 01:43 PM
Furnace room is warm, wasting heat Richo HVAC 13 02-18-2009 01:57 PM
Sunlight for a Basement Room prglor Remodeling 1 08-31-2008 05:29 PM
I Found a Secret, Hidden, Unused Room sweaty General DIY Discussions 16 08-01-2008 03:45 PM
