How Do I Seal Gaps In My Floor? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-20-2013, 09:50 AM   #1
Rewards Points: 14
How do I seal gaps in my floor?
Hello,
I just wanted to get a few different opinions on how to accomplish this the "right" way. My house was built back in the 50's and I was recently sanding and working on redoing the closet in one of the bedrooms when I came across some nasty black paper which I assume was tar paper. The house has a crawl space underneath this portion. I tore out the tar paper and currently have gaps in the "sub floor" in which bugs spiders etc can crawl up from under neath. I was wondering how best to fill these gaps. Keep in mind I will be painting and primering the whole closet area and there will be 4 drawers covering this up so it's very unlikely anyone will see this unless they remove the drawers...The ideas I came up with were #1 Caulking it and painting it #2 redoing the tar paper (not a fan of this) #3. using some cheap vinyl squares underneath (still relatively expensive)
socrates is offline   Reply With Quote
Old 02-20-2013, 10:05 AM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by socrates View Post
I was recently sanding and working on redoing the closet in one of the bedrooms when I came across some nasty black paper ... I tore out the tar paper and currently have gaps in the "sub floor"
I just wanted to get a few different opinions on...
OK. You need to add the missing "finished floor" layer.
(along with some new tar paper or it's modern version)
Something like this:
Old 02-20-2013, 10:09 AM   #3
Rewards Points: 14
even though it doesn't really matter what it looks like and will most likely never be seen?
Old 02-20-2013, 11:22 AM   #4
MarginallyQualified
Yeah. You need to seal it up with a solid layer. You could do that with a simple layer of plywood or some of that crappy pergo stuff.
The cosmetics of what you use are don't matter.
The Following User Says Thank You to TarheelTerp For This Useful Post:
drtbk4ever (02-20-2013)
Outside Air Leaking in From Gaps Where Floor and Wall Meet benchmarkman Building & Construction 17 11-02-2016 07:37 AM
Mid span bridging lylsutherland Building & Construction 2 10-29-2012 11:10 PM
Should I seal gaps around the basement concrete floor? wyx2000 Concrete, Stone & Masonry 7 10-18-2012 12:36 PM
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
seal odors in conrete floor ejpopow Flooring 9 10-09-2008 01:14 PM
