How Do I Repair This Column? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-29-2012, 01:03 PM   #1
aquaholic's Avatar
Rewards Points: 29
How do I repair this column?
I have this column at my house that is a big PITA! I've had a few people come 'fix' it and each time I think they just throw a bigger bead of caulking which doesn't last. What would be the proper way to fix this once and for all? Thanks!
aquaholic is offline   Reply With Quote
Old 01-29-2012, 01:11 PM   #2
Experienced
Jackofall1's Avatar
A picture with more of the column and its surrounding would be better to help you out.
Mark
Old 01-29-2012, 01:16 PM   #3
Rewards Points: 14,306
Impossible to say from those pictures.
What's wrong with them?
What are they made of?
If there wood then they should not have been installed in direct contact with the deck, they should have been mounted on bases. I make mine out of PVC lumber.
There was also suppost to be drain holes at the bottom to dry out the inside and allow moisture to drain.
Old 01-29-2012, 01:28 PM   #4
biggles's Avatar
bag a Sakrete cement...strain it into a bucket with window screen real fine mix it to a pourable consistantcy and pour it into the cracks forget the caulking crap...let it seep in and cure then hit it again..pre blast it with a hose or nozzle to remove loose stuff and pre wet it before pour
Old 01-29-2012, 01:30 PM   #5
aquaholic's Avatar
Rewards Points: 29
Heres a better picture. They don't feel like wood, feels like plastic?
Old 01-29-2012, 01:33 PM   #6
Far more likly there fiberglass.
Ok so what's going wrong with them?
What have they been using to paint them?
Old 01-29-2012, 01:44 PM   #7
aquaholic's Avatar
Rewards Points: 29
The problem is that caulking that keeps lifting off. I'm worried that when it rains water can get in through there and damage the structure? Paint is standard dun Edwards acri-flat.
Old 01-29-2012, 01:47 PM   #8
aquaholic's Avatar
Rewards Points: 29
So there's nothing down there that can be damaged by filling with cement? I just want to have a nice interface between the column and stucco that lasts and looks nice.
Old 01-29-2012, 01:47 PM   #9
if you can't see anything in the photo before you send it. we cant see anything after you send it!
Hardway is offline   Reply With Quote
Old 01-29-2012, 01:56 PM   #10
joed's Avatar
Rewards Points: 13,738
What's your location? How old is that since the last fix?
Looks like standard seasonal expansion and contraction causing the caulking to split. perhaps a more rubbery caulking? I would suggest a polyurethane caulk. Around here it costs $7 a tube instead of the $1.50 the other stuff costs.
Old 01-29-2012, 01:59 PM   #11
aquaholic's Avatar
Rewards Points: 29
I'm in Las Vegas. It's probably been 2 years since the last fix.
Old 01-29-2012, 02:03 PM   #12
If it's PVC or fiberglass then it should not be sealed at the bottom. Water is not going to hurt it. By adding caulking you have just made a damm to hole in moisture and it will have no way to get out once the caulking fails.
Old 01-30-2012, 06:41 AM   #13
Mold!! Let's kill it!
Rewards Points: 2,012
To me it looks like the bases are decorative and coated with "Dryvit" or some other stucco type finish. I would guess from the pictures, that whoever installed the Dryvit didn't use a bond breaker against the plastic column cover or caulked the Dryvit fast to the cover. Now when the column cover expands and contracts it tears the Dryvit. My guess is that there is a solid post inside to bear any load and everything you see is decorative. My opinion is that the bases need to be taken apart and redone by someone who knows how to create a dynamic joint. The sealant is actually what caused the problem in the first place.
Old 02-04-2012, 05:31 PM   #14
aquaholic's Avatar
Rewards Points: 29
I was hoping for an inexpensive fix that I could maybe do myself? Taking those columns apart sounds expensive.
Old 02-06-2012, 12:50 PM   #15
Rewards Points: 626
I would tear that base apart and fix it right plus what id there is rot going on in there? Call a contractor and get it done right.
Nailbags is offline   Reply With Quote
Repair or Replace Garage Doors??? jbird0005 Windows and Doors 2 12-10-2011 06:42 AM
Porch column base rotted RickO General DIY Discussions 17 10-25-2011 08:43 PM
Injected too much foam sealer to repair tub, how to remove foam? amodoko Plumbing 4 08-16-2011 12:42 PM
Tranferring load to basement beam and lally column cooperwd Building & Construction 3 08-17-2009 10:14 AM
fiberglass column repair christoni General DIY Discussions 3 06-26-2005 11:15 PM
