How Do I Remove White Spots On Metal? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-02-2012, 01:35 PM   #1
How do I remove white spots on metal?
Ever since I bought my home I've noticed there's what appears to be white water spots on the metal doors, flashing, etc. Based on the patterns and locations I assume it's caused by the rain. I've tried everything from CLR to diluted vinegar to no avail.
An no, it's not bird droppings. It's flat and texture-less like a stain and is on smaller vertical surfaces throughout the property.
Has anyone else experienced this and found a solution? Any help is appreciated, thanks.
robmarston is offline   Reply With Quote
Old 05-02-2012, 01:40 PM   #2
concretemasonry's Avatar
Rewards Points: 2,578
Since you did not post your location, which is strongly suggested, where are you since the climate many have a clue.
Dick
concretemasonry is offline   Reply With Quote
Old 05-02-2012, 01:48 PM   #3
Dick, I'm in Los Angeles California. Very little, albeit most likely acidic, rain.
Old 05-02-2012, 02:13 PM   #4
Rewards Points: 33
is that an aluminum door? aluminum does oxidize. it needs anodizing.
bionictony is offline   Reply With Quote
Old 05-02-2012, 08:41 PM   #5
I believe it is aluminum, yes. If that's the case than its probably too late to save it right?
Old 05-08-2012, 01:22 AM   #6
Rewards Points: 13,256
If it was mine I would be looking into any place that does powder coating.
They could strip it and recoat it.
Anidizing is sort of like stain, Powder coating is more like a paint.
It will act as a sealer. It's done on things like engine parts, boat and home railings. It's tough stuff.
Old 05-08-2012, 11:32 AM   #7
You must be used a polish for remove white spot on metal and any spot removal powder this is best for spot removing you should be purchase these items and take a try by use them
Adonis1 is offline   Reply With Quote
Tags
clean , flashing , metal , spot , stain
How to remove metal fence posts? sk8z Landscaping & Lawn Care 17 04-04-2012 05:54 PM
white spots on gea verda tile around salt water pool mayo2965 Tiling, ceramics, marble 9 11-13-2009 06:37 AM
Tool to remove metal? darsunt Building & Construction 5 05-16-2008 04:01 PM
How do you remove plastic coupling nut and washer from braided metal connector? tony__s Plumbing 3 05-15-2008 11:15 PM
TrafficMaster grout f.y.i. denman Flooring 16 07-01-2007 04:07 PM
