How do I remove white spots on metal?
Ever since I bought my home I've noticed there's what appears to be white water spots on the metal doors, flashing, etc. Based on the patterns and locations I assume it's caused by the rain. I've tried everything from CLR to diluted vinegar to no avail.
http://www.thedarkharbor.com/web/photo.jpg An no, it's not bird droppings. It's flat and texture-less like a stain and is on smaller vertical surfaces throughout the property. Has anyone else experienced this and found a solution? Any help is appreciated, thanks. |
Since you did not post your location, which is strongly suggested, where are you since the climate many have a clue.
Dick |
Dick, I'm in Los Angeles California. Very little, albeit most likely acidic, rain.
is that an aluminum door? aluminum does oxidize. it needs anodizing.
I believe it is aluminum, yes. If that's the case than its probably too late to save it right?
If it was mine I would be looking into any place that does powder coating.
They could strip it and recoat it. Anidizing is sort of like stain, Powder coating is more like a paint. It will act as a sealer. It's done on things like engine parts, boat and home railings. It's tough stuff. |
You must be used a polish for remove white spot on metal and any spot removal powder this is best for spot removing you should be purchase these items and take a try by use them
| All times are GMT -4. The time now is 01:38 PM. |
