How Do I Hang Heavy Bag - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-05-2013, 04:22 PM   #1
Hello, I have a outdoor patio area with a roof. The roof has rafters running across about 18" apart. The rafters are about 15 ft long. I'd like to hang a 100 lb heavy bag near the center of this patio area and wanted to know what I need to have a secure mounting point.
If I could connect a piece of wood across 2 or 3 rafters, I could insert an IBolt through this board possibly. Question is, what is the correct way to join these pieces of wood together (board to rafters)? I don't have access to above the rafters. Details would be greatly appreciated and I probably won't understand most fancy words I've seen when googling around. Please help!
It looks something like this but outdoors:
http://cffiles.thesimsresource.com/s...89-1527205.jpg
howdoi is offline   Reply With Quote
Old 05-05-2013, 08:16 PM   #2
Couple options.
You could run a 2x4 perpendicular to the rafters, secured with lag screws. You could drill a hole through one rafter and loop a carabiner through it and secure another carabiner to it. OR, my favorite :
http://www.ironcompany.com/woodenbea...xinghbh-1.aspx
Mickey: You're gonna eat lightnin' and you're gonna crap thunder!
Occam's Razor - The simplest answer is probably the correct one.
JCAHILL4 is offline   Reply With Quote
Old 05-05-2013, 10:10 PM   #3
Rewards Points: 446
You could anchor (lag bolt) a length of angle iron across some rafters (I'd catch 3 at least) from the bottom and then use a shackle to hang the bag from. Make sure the iron and shackle is heavy enough to support the weight. Paint before you put it up to match the ceiling.
http://en.wikipedia.org/wiki/Shackle
old_squid is offline   Reply With Quote
Please help me figure out how to hang heavy bag in basement. llO0DQLE Building & Construction 4 04-05-2013 10:14 AM
strong enough to hang heavy bag? twiggyBD Building & Construction 23 02-08-2013 06:53 PM
What is the best way to hang a heavy antique wood framed mirror to a glass wall jimmcfarlane Building & Construction 3 10-11-2012 07:06 AM
Help to hang heavy mirror robwallis Interior Decorating 2 08-17-2010 05:01 PM
Phone will not hang up--help! rudy6380 Electrical 2 06-29-2008 08:25 PM
