How Do I Fix This? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-02-2013, 12:49 AM   #1
Rewards Points: 89
How do I fix this?
The electrical outlet is falling off the wall. How do I fix this?
Fly_on_the_wall is offline   Reply With Quote
Old 12-02-2013, 02:03 AM   #2
747
registered
747's Avatar
Rewards Points: 534
I'm thinking install new box with a oscar(aka battleship) to hold it.
747 is offline   Reply With Quote
Old 12-02-2013, 06:55 AM   #3
Rewards Points: 1,294
Is there even a box behind it?????? I would be suspicious of all the other work done in that house. If you are unsure about how to fix this, then maybe it is time to call in an electrician. You may want him to look at the rest of the electric as well.
danpik is offline   Reply With Quote
The Following User Says Thank You to danpik For This Useful Post:
del schisler (12-02-2013)
Old 12-02-2013, 07:38 AM   #4
Rewards Points: 5,974
Looks like you can see the edge of the box, but I don't see the tabs for the screws. Anyway change the box, that looks like the old box that was nailed to a stud. Run a hacksaw blade up the outside of the box cutting the nails off then get a old work box (just the name not used) and install. Of course turning the power off.
Old 12-02-2013, 07:51 AM   #5
PoleCat's Avatar
Rewards Points: 1,646
The neutral wire is around the screw the wrong way so it looks like that outlet may have been changed by a novice. Some of those plastic boxes have very little strength in the screw holes and running them in with a power driver too tight will destroy them. You may be able to get it back together by putting toothpicks in the holes then screwing the outlet back down.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is online now   Reply With Quote
Old 12-02-2013, 08:00 AM   #6
Rewards Points: 12,840
Try another picture so we can see if there's even tabs on the box where the screws should holding the outlet in place.
It should look like this.
http://www.hardwarestore.com/handy-box-238329.aspx
Going to have to cut out that loose paper, Prime with Gardz then fill that area with joint compound. Use thin layers and build it up or it's going to crack unless you use hot mud for the first coat.
Old 12-02-2013, 07:53 PM   #7
Rewards Points: 89
Here's a different angle showing the box.
Old 12-02-2013, 07:53 PM   #8
Rewards Points: 89
The box is kind of pushed back.
Old 12-02-2013, 08:29 PM   #9
JOATMON
ddawg16's Avatar
Rewards Points: 820
That sure is a small box
I'm thinking it's Sawzall time.....
Old 12-02-2013, 08:35 PM   #10
joed's Avatar
Rewards Points: 11,576
Clean up the hole and instal a box extender to bring it out to the face of the wall.
The Following User Says Thank You to joed For This Useful Post:
ToolSeeker (12-03-2013)
Old 12-02-2013, 09:13 PM   #11
JOATMON
ddawg16's Avatar
Rewards Points: 820
Sawzall would be more fun......but....a box extender would be better
Old 12-03-2013, 09:32 PM   #12
Rewards Points: 89
Ok. So are these the correct steps?
1. Clean up the hole and install a box extender to bring it out to the face of the wall.
2. Place the neutral wire around the screw in the right direction.
3. Cut out that loose paper, prime with Gardz then fill that area with joint compound. Use thin layers and build it up or it's going to crack unless you use hot mud for the first coat.
I just want to make sure.
Old 12-03-2013, 10:12 PM   #13
Sounds like a plan.
Old 12-03-2013, 10:35 PM   #14
747
registered
747's Avatar
Rewards Points: 534
Yes and the lastest pic shows a real mess. Clean it up and box extender
