Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 02-25-2005, 11:43 PM   #1
How do I fill wide gap between tub and tile...caulk?
There is a large gap between my bathtub and the ceramic tiles on the walls due to settling over the years. How do I make this gap waterproof? Will silicone caulk fill a gap of one inch or more or do I need to use some other material or product? Help! Thanks.
Derby is offline   Reply With Quote
Old 02-26-2005, 08:00 AM   #2
Paperhanger/painter
ProWallGuy's Avatar
1" or more, holy cow, thats a lot of settling.
We use 'backing rod' in large gaps before caulking, but not sure if its made that big.
ProWallGuy
ProWallGuy is offline   Reply With Quote
Old 02-26-2005, 03:16 PM   #3
Contractor
I think that you need to discover why the tub is settling. 1" is a long way for a tub to go!
Teetorbilt is offline   Reply With Quote
Old 03-17-2005, 07:10 PM   #4
WOW!
I would use a polymer modifed saltillo grout (problem is color selection) We have done some odd large fills with standard modified grout...tho it may crack. Make sure the tub is done moving...you could have a big problem on your hands
Mark Lauzon
www.stoneadvice.com
slab fabricator heaven
Mark Lauzon is offline   Reply With Quote
Old 03-22-2005, 12:19 AM   #5
I'm thinking you'd be better off jacking that tub back up and reinforcing it. After you get that gap to less than a half an inch, I'd go with a standard tile wall grout. Do not use a pre mixed grout from a bucket. That is not for wet areas. Get the dry, non-sanded grout in the color of your choice. For filling a gap more than 1/8th of an inch, you should use a thick mixture, and be sure to use a rubber grout applicator, then wipe it with a soft wet sponge, or cheese cloth to smooth and form the joint. I think you'll be happier with this repair than if you caulk it. Caulking tends to mold in bathtubs, and peels away from the tile and/or tub, causing more leaks.
Tomm is offline   Reply With Quote
