How Do I Cut A Hole In The Bottom Of A Pail? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-06-2007, 09:34 AM   #1
Question
How do I cut a hole in the bottom of a pail?
Hey guys,
I need to get a hole in the bottom of this 5-gallon pail, it's being attached to PVC and it doesn't matter if the hole is a circle (like drawn on it) or if it's a square or whatever, as long as it's big and it fits within the circle.
But how the heck do I get a chunk within the circle out?
I don't have any fancy machinery and then the tools that I do have are all dead. And after spending $56 on PVC and crap today I guarantee I'm not going to be buying anything else for the next week.
Any help would be appreciated.
andrgo is offline   Reply With Quote
Old 01-06-2007, 10:14 AM   #2
hole
Predrill a 1/2" hole then use a bimetal blade in a jigsaw worked fine for me
rick32 is offline   Reply With Quote
Old 01-06-2007, 10:18 AM   #3
Sorry should have finished reading the post before i replied. a lot of scores with a good utility knife will do the trick be patient though those blades have been known to snap and bite lol
Old 01-06-2007, 10:26 AM   #4
Just stare at it like superman would and melt it with your laser eyes.Just kidding use a utilaity knife and common sense.
trollmastergeneral is offline   Reply With Quote
Old 01-06-2007, 10:58 AM   #5
Lawn Care/Handyman Serv.
Work a small cut with a utility knife (away from your line toward the center) and then take a tin snips/aviation snips and work your way over to the line and cut it out.
Dave
EZ Rider is offline   Reply With Quote
Old 01-06-2007, 11:18 AM   #6
Journeyman Plumber
Ron The Plumber's Avatar
Borrow a hole saw, fast and clean.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 01-07-2007, 09:52 AM   #7
A hot butter knife.
tkle is offline   Reply With Quote
Old 01-07-2007, 10:25 AM   #8
As a matter of fact use his drill and electricty and you could save even more
Old 01-07-2007, 10:33 AM   #9
joed's Avatar
Rewards Points: 12,914
Find a can the same size as your hole. Heat it up and melt a perfect round hole. Or cut saw teeth in the edge and use it like a saw.
Old 01-07-2007, 01:21 PM   #10
remodeling pro
Drill a couple of holes in a row to form a slot along the intended cut line, then insert a hacksaw blade and cut away. Surely you want this hole bad enough to invest a couple of dollars in a hack saw blade.
As for the utility knife cutting through a five gallon pail, make an appointment at the local doctors office first, one who is good at stitching things back together.
Easiest one of course is a jig saw. Don't you have friends with tools
troubleseeker is offline   Reply With Quote
Old 01-07-2007, 01:33 PM   #11
Remember he said he is broke.He can come to michigan and I will loan him my hole saw ,a power drill and a 110v plug to get the job done
Tool to deepen deadbolt hole? darsunt Carpentry 5 07-18-2007 10:45 PM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 07:17 AM
I hope I don't have to tear down the ceiling brds16 Carpentry 9 04-30-2005 10:16 AM
